[OpenLayers-Users] WFS layer not visible
Nipuni Perera nipuni880917 at gmail.com
Wed Jun 5 09:05:36 PDT 2013
This is what I got with error.log file:
SyntaxError: invalid syntax\r, referer: http://localhost/temp/temp.html
Premature end of script headers: proxy.cgi, referer:
File "C:/Server/Apache22/htdocs/temp/proxy.cgi", line 45\r, referer:
print "Status: 502 Bad Gateway"\r, referer: http://localhost/temp/temp.html
                             ^\r, referer: http://localhost/temp/temp.html
Thanks,
Nipuni
On Wed, Jun 5, 2013 at 10:30 AM, Raffaele Morelli <
raffaele.morelli at gmail.com> wrote:
> 2013/6/5 Nipuni Perera <nipuni880917 at gmail.com>
>> Hi,
>> Yes I have Python installed and the first line of the proxy.cgi is
>> #!C:/Python33/python.exe -u
>> which points to the python.exe location.
>> I have set the changes to httpd.conf file as described here<http://vijaysambhe.wordpress.com/2012/10/12/openlayers-cross-domain-configure-proxyhost-on-windows/>.
>> I have reinstalled Python and the response change from the script to an
>> error message. This is the response I received for the POST request:
>> <!DOCTYPE HTML PUBLIC "-//IETF//DTD HTML 2.0//EN"><html><head><title>500 Internal Server Error</title></head><body><h1>Internal Server Error</h1><p>The server encountered an internal error ormisconfiguration and was unable to completeyour request.</p><p>Please contact the server administrator, admin at example.com and inform them of the time the error occurred,and anything you might have done that may havecaused the error.</p><p>More information about this error may be availablein the server error log.</p></body></html>
>> This is the same error message I get when I try to open the proxy.cgi from localhost.
>> Thanks,
>> Nipuni
> You should have a look at apache error log, it's clearly a
> misconfiguration in apache (error 500) and what you need for debug is there.
> I would suggest to check directory and/or file permissions (ie. virtual
> host configuration directives).
> /r
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
Nipuni Piyabasi Perera
Undergraduate
Department of Computer Science And Engineering
University of Moratuwa
Sri Lanka
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20130605/18c4f5d0/attachment-0001.html>
