[OpenLayers-Users] Accessing user defined data from a OpenLayers application
Nipuni Perera nipuni880917 at gmail.com
Wed Jun 5 18:09:19 PDT 2013
I have hadded 'localhost:8080' to the proxy.cgi and now it works. (Earlier
I only had 'localhost' in it).
Thanks,
Nipuni
On Thu, Jun 6, 2013 at 2:25 AM, Phil Scadden <p.scadden at gns.cri.nz> wrote:
> >Status: 502 Bad Gateway>Content-Type: text/plain
> >This proxy does not allow you to access that location (api.flickr.com
> If you look at the logic for the proxy, you will see that this is what you get for not having api.flickr.com in your
> allowedHosts. Make sure port also matches. Check for spelling etc. Log the incoming URL if possible and compare with allowedHosts
> Phil Scadden, Senior Scientist GNS Science Ltd 764 Cumberland St, Private
> Bag 1930, Dunedin, New Zealand Ph +64 3 4799663, fax +64 3 477 5232
>  Notice: This email and any attachments are confidential. If received in
> error please destroy and immediately notify us. Do not copy or disclose the
> contents.
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
Nipuni Piyabasi Perera
Undergraduate
Department of Computer Science And Engineering
University of Moratuwa
Sri Lanka
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20130606/b70edd24/attachment.html>
