[OpenLayers-Users] ol2.13 and old ticket 3621 calculateResolutions
Steve.Toutant at inspq.qc.ca Steve.Toutant at inspq.qc.ca
Tue Jun 11 06:46:49 PDT 2013
We have this issue with 2.10 as well. I didn't try with earlier version.
I repeat that the problem is in chrome only.
I tried testing typeof.....function in chrome
<script type="text/javascript">
var numZoomLevels; //tried with null, 20, '20', 'aaa'
if(typeof numZoomLevels !== "number")
        alert('nan');
alert(isNaN(numZoomLevels));
</script>
typeof numZoomLevels !== "number" and isNaN(numZoomLevels) work.
I also created a simple application with 500 openstreetmap in the
layerswitcher, I didn't have any problem since numZoomLevels never
changed, always = 20 as defined in the mapOptions.
In our application we have 460 layers, some of them have minscale,
maxscale settings, so numZoomLevels is not the same for each layer.
For some reason, numZoomLevels as a value that only isNaN(numZoomLevels)
can manage well in Chrome
This problem appears since we have 450 wms layers.
I'm still trying to create a test case but it is difficult.
steve
Bart van den Eijnden <bartvde at opengeo.org>
2013-06-10 14:23
A
cc
Bart van den Eijnden <bartvde at opengeo.org>,
openlayers-users at lists.osgeo.org
Objet
Re: [OpenLayers-Users] ol2.13 and old ticket 3621 calculateResolutions
Also Steve, what version of OpenLayers do you run now where you don't have
this issue?
Best regards,
Bart
OpenGeo - http://opengeo.org
Expert service straight from the developers.
On Jun 10, 2013, at 7:35 PM, Steve.Toutant at inspq.qc.ca wrote:
This problem is happening since we have more than 450 wms layers. It is
difficult to create a test case since we are using a complex application
built with extjs/geoext and OL. We are using a geoext layertree, not a
layer switcher.
The crash happens in openlayers/Layer.js
What would be a good test case? Should I create just an OL map with 450
layers in the layerswitcher?
thanks
steve
2013-06-10 02:42
A
cc
Objet
Steve,
can you show us an example to reproduce this?
Best regards,
Bart
On Jun 7, 2013, at 9:45 PM, Steve.Toutant at inspq.qc.ca wrote:
We have a problem with OL2.13 in Google Chrome only.
Here is the error message: Uncaught RangeError: Invalid array length
Layer.js line 1050
It seems to be related to this issue
http://trac.osgeo.org/openlayers/ticket/3621
it fails because numZoomLevels is NaN
But this code at line 1042 should manage that....
// are we able to calculate resolutions?
       if(typeof numZoomLevels !== "number" || numZoomLevels <= 0 ||
(typeof maxResolution !== "number" &&     typeof minResolution !==
"number")) {
           return;
I fix it adding isNaN(numZoomLevels)
       if(isNaN(numZoomLevels) || typeof numZoomLevels !== "number" ||
               typeof minResolution !== "number")) {
           return;
I went on github but could not find the issue.
So I submit here
Steve_______________________________________________
Users mailing list
Users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/openlayers-users
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20130611/315ec21f/attachment.html>
