[OpenLayers-Users] Create Objects from Database
    gabriel
    gpetricek at gmail.com
    Fri Mar 22 04:13:26 PDT 2013
if you want only read data from database try this:
new layer = new ol.Layer.Vector("vehicle",
                      strategies: [new o.Strategy.BBOX()],
                      protocol: new o.Protocol.WFS
                        url:<url to your mapserver>,
                        featureType:"<name of the table you want to add>",
                        featureNS:"<namespace>",
                        geometryName:"<geometry name, default is the_geom>",
                        version:"1.1.0" // version of WFS
map. addLayer(layer);
Ofcourse, this example works with mapserver (MapServer, Geoserver....)
If you want to add new obects into table you must create saveStrategy object
and add it to layer.
For example:
 var saveStrategy = new ol.StrategySave();
var layer = new ol.Layer.Vector("name",{
  strategies: [new o.Strategy.BBOX(), saveStrategy],
Then you need to create for example button to save new geometry.
var button = document.getElementById("button_save");
button.onclick = function() {
 saveStrategy.save();
This process will save only geometry into table. If you want to add
attributes too you should do something like this:
var layer = new ol.Layer.Vector("name", {
 strategies:.....,
 protocol({.....}),
 eventListener:{
  beforefeatureadded:function(e)
   e.feature.attributes.buffer = window.prompt("add buffer value");
 thats only example.
 There is another
:http://openlayers.org/dev/examples/wfs-protocol-transactions.html
Last thing, you need to create draw control, to draw vectors(polygon, point,
line).
Look this http://openlayers.org/dev/examples/draw-feature.html
View this message in context: http://osgeo-org.1560.n6.nabble.com/Create-Objects-from-Database-tp5042303p5042317.html
