[OpenLayers-Users] (Geoserver + OpenLayers) Search item by coordinates (lat/long) or id
Gery . gamejihou at hotmail.com
Tue May 14 08:07:35 PDT 2013
It seems that you need a search function. If so this could help you to start:
http://ian01.geog.psu.edu/geoserver/www/search/gazetteer.html
http://ian01.geog.psu.edu/geoserver_docs/apps/gaz/index.html
http://gis.stackexchange.com/questions/20878/how-to-implement-feature-search-in-openlayers-with-geoserver
Sent from my iRon
On May 14, 2013, at 15:33, "João Carlos Zakrzevisk" <jcarlaop at gmail.com> wrote:
I'm using Geoserver (2.3.0) + OpenLayers(2.12), but with no previous experience on GEO systems :(.
I need to locate in the map the item located in lat/long, or by the primary key. But I have found only the inverse situation, in other words, if the user clicks on item, it is possible to recover the lat/long.
Someone knows how to find this item?
Users mailing list
Users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/openlayers-users
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20130514/1dba1b0a/attachment.html>
Users mailing list
