[OpenLayers-Users] ZoomBox outside extent?
Tondo gpktondo at gmail.com
Wed May 15 11:29:15 PDT 2013
Hi lists,
1.) If you try to use ZoomBox out of map's extent, control won't try at
least zoom the nearest part of map. It will center your view instead.
2.) If you drag your ZoomBox control and not release left mouse button but
hit the right one instead, draw rectangle won't fade. It's going to remain
visible even if map is zoomed/panned.
Reproduced successfully at
http://openlayers.org/dev/examples/navtoolbar-alwaysZoom.html (tried both
alwaysZoom true/false)
Is there any way to evade such a behavior?
Regards,
Tom
View this message in context: http://osgeo-org.1560.x6.nabble.com/ZoomBox-outside-extent-tp5053483.html
