[OpenLayers-Users] Controling cache size and storage location for CacheWrite
Nick Karnik nkarnik at intven.com
Fri May 17 13:36:59 PDT 2013
Hello,
I'm using the CacheWrite control and running into an issue with the Local Storage filling up quickly so I was wondering if any of the following are possible in the current 2.13 codebase:
1.       Can I limit the amount of space reserved for the OL Cache? I'm using LocalStorage for storing other data in my application and running out of space pretty quickly due to the map cache. I know I can clear the MapCache when that happens, but that's my last resort.
2.       Can I configure the CacheWrite control to use Session Storage/IndexedDB instead of the Local Storage?
3.       What about having OL cache use an in-memory cache?
Are there any work around for this issue other than using IndexedDB or clearing the map cache?
Thanks,
Nick Karnik
Software Engineer, EMOD
nkarnik at intven.com<mailto:nkarnik at intven.com>
T - 425.691.2772
F - 425.467.2350
[Description: Macintosh HD:private:var:folders:zw:nhpyfsj15yz5p_qn04yzr5cm0000gn:T:TemporaryItems:GG_Logo_PMS 356.png]
This message may contain confidential information which may also be legally privileged information. If you are not an intended recipient of the message, please delete it and notify the sender via reply email.
Any unauthorized dissemination, distribution or copying of the material in this message, and any attachments to the message, is strictly forbidden.
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20130517/fb362cca/attachment.html>
Type: image/png
Desc: image001.png
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20130517/fb362cca/attachment.png>
