[OpenLayers-Users] drillDown: multiple requests but only first in pop-up
Giuseppe De Marco peppelinux at yahoo.it
Wed May 22 15:20:55 PDT 2013
Thank you,
so the only method for querying all the visible layers is declaring [ layer1, layer2, layer3 ] in layers attribute of getfeatureinfo ?
 Da: Bart van den Eijnden <bartvde at opengeo.org>
A: Giuseppe De Marco <peppelinux at yahoo.it>
Cc: "openlayers-users at lists.osgeo.org" <openlayers-users at lists.osgeo.org>
Inviato: Mercoledì 22 Maggio 2013 19:55
Oggetto: Re: [OpenLayers-Users] drillDown: multiple requests but only first in pop-up
Please see the api docs, this does not work with HTML, you need something like GML as the output format for GetFeatureInfo.
     * APIProperty: drillDown
     * {Boolean} Drill down over all WMS layers in the map. When
     *     using drillDown mode, hover is not possible, and an infoFormat that
     *     returns parseable features is required. Default is false.
Best regards,
Bart
OpenGeo - http://opengeo.org
Expert service straight from the developers.
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20130522/5a17e169/attachment.html>
