[OpenLayers-Users] WMS layer not visible...
Phil Scadden p.scadden at gns.cri.nz
Sun May 26 16:09:26 PDT 2013
You should always use maxExtent - if you dont OL guesses which I think
works okay if the map projection is 4326 or 900913 in 2.12. MaxExtent is
used in calculating whether to make WMS calls (is the layer in range). A
mismatch in the projection information between the WMS layer, map
projection and baseLayer projection is probably cause of havoc.
Notice: This email and any attachments are confidential.
If received in error please destroy and immediately notify us.
Do not copy or disclose the contents.
