[OpenLayers-Users] Use of Geoserver Pritning Module with OpenLayers client?
Gery . gamejihou at hotmail.com
Tue May 28 12:42:44 PDT 2013
Hello Ben,
I don't think it's too difficult or too much work to implement some things of geoext with openlayers. A very common reference afaik is the MapFish demo, probably you know that already. There are some other tools out there, but I think they provide only png or jpg files.
Hope this helps,
Gery
Sent from my iRon
On May 28, 2013, at 21:25, "Benjamin Krepp" <bkrepp at ctps.org> wrote:
Dear colleagues,
I have a couple of OpenLayers apps (backed by Geoserver) to which I’d like to add the ability to print the map in .pdf format. The Geoserver Printing Module (http://docs.geoserver.org/latest/en/user/community/printing/index.html) looks like it would provide the server-side support I’m looking for.
However, the documentation for the Print Module indicates that the print service it supports is meant to be used from GeoExt client-side apps. For a variety of reasons (not the least of which is budget limitations) I’m not in a position to re-implement the OL apps in question using GeoExt.
Given this, I have a couple of questions:
1.       Does anyone know if a plain-vanilla OpenLayers app can successfully make use of the Geoserver Printing Module service? If anyone does, I’d appreciate reference(s) to working sample code.
2.       If (1) is not possible, is there some approach that would work that wouldn’t require re-writing the whole app to use GeoExt? For example, might it be possible to use GeoExt only in a very limited way (e.g., manage the ‘map canvas’) and rely on the existing body of OL code to handle everything else (e.g.,  manage on-screen controls, generation/display of legends, etc.) and still be able to exploit the Print Module? If the answer is ‘yes’, pointers to sample working code would be appreciated.
Since the answer to these questions might be found in either the GeoSever or OpenLayers communities, I’m posting this inquiry to both mailing lists. My apologies if you receive these questions twice.
Thanks in advance for any help you can offer with this.
Best regards,
Ben Krepp
Benjamin Krepp  |  Manager of GIS and IT
CENTRAL TRANSPORTATION PLANNING STAFF
617.973.7137  | bkrepp at ctps.org
www.ctps.org/bostonmpo
<image001.png>
Users mailing list
Users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/openlayers-users
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20130528/92e41998/attachment.html>
Users mailing list
