[OpenLayers-Users] openlayer markers located at the wrong place
maven apache apachemaven0 at gmail.com
Fri May 31 01:33:37 PDT 2013
Mario Danelli:
Thanks for your attention and the codes.
It seem that the `OpenLayers.Marker` have no native support methods like
`setPosition()` or something else to update its position.
Since in my opinion, destroy-create-destroy.. will be a performance consuming
problem, that is why I keep one object of  `Marker` to reuse it.
I think it is a pity.
APIs like this kinds should be considered.
And I hope the development team of OL will notice this post. :)
And thank you anyway. :)
2013/5/31 Mario Danelli <mario.danelli at gmail.com>
> Dear Maven,
> > As you can see, once I click on the map, I want the marker's position
> updated and re-located.
> As you can see, from the following link too
> http://stackoverflow.com/questions/9278174/how-to-move-a-marker-in-an-openlayers-layer-markers-layer
> It seems that the "moveTo" -- is not "official" APIMethod -- or in any case
> there are some problems with it.
> So I tried removing and adding a new marker at any click on map.
> Below the JS code, that runs as expected, I tried in your example.
> As you can see I changed the code of "updateMaker" function.
> ---------> BEGIN
> $(window).load(function() {
>         var map = new OpenLayers.Map("map");
>         map.addControl(new OpenLayers.Control.MousePosition());
>         var osm = new OpenLayers.Layer.OSM();
>         map.addLayer(osm);
>         // Set view to zoom maximum map extent
>         map.zoomToMaxExtent();
>                 var markers = new OpenLayers.Layer.Markers("Markers");
>                 map.addLayer(markers);
>         myMarker = new OpenLayers.Marker(new OpenLayers.LonLat(0,0));
>                 markers.addMarker(myMarker);
>                 map.events.register("click", map, function(evt) {
>                         var pos = map.getLonLatFromPixel(evt.xy);
>                         updateMaker(myMarker, pos);
>                 function updateMaker(myMarkerIn, pos) {
> //myMarker.moveTo(myMarker.map.getPixelFromLonLat(pos));
>                    markers.removeMarker(myMarkerIn);
>            myMarkerIn.destroy();
>            myMarker = new OpenLayers.Marker(pos);
> <--------- END
> I hope it can be useful.
> Regards
> Mario Danelli
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20130531/df548275/attachment.html>
