[OpenLayers-Users] WFS with both point and polygon features
Ipad dalvarez100 at gmail.com
Tue Nov 12 10:02:59 PST 2013
Check that the xml response from the server (I use firebug for mozilla), the namespace is correct for the info you're carrying.
> Message: 1
> Date: Sun, 10 Nov 2013 13:09:12 -0500
> From: "Jerome A. Wendell" <jawendell at suddenlink.net>
> To: "'adityakumar529'" <adityakumar529 at gmail.com>,
>    <openlayers-users at lists.osgeo.org>
> Subject: Re: [OpenLayers-Users] WFS with both point and polygon
>    features
> Message-ID: <001e01cede3f$f63c5ca0$e2b515e0$@net>
> Content-Type: text/plain;    charset="us-ascii"
> Do you have other layers from that source that are loading correctly?  Could
> it be a firewall issue?
> Jerome Wendell
> -----Original Message-----
> From: openlayers-users-bounces at lists.osgeo.org
> [mailto:openlayers-users-bounces at lists.osgeo.org] On Behalf Of
> adityakumar529
> Sent: Sunday, November 10, 2013 11:49 AM
> To: openlayers-users at lists.osgeo.org
> Subject: [OpenLayers-Users] WFS with both point and polygon features
> Dear Users,
>   I have a layer published from Geoserver which has both point and polygon
> features in it. When I am loading this data on the map, in the firebug I can
> see the layer in loading as the XML request is working fine.But the layer is
> not loading on the map. Any suggestion to bring this layer load on the map?
> I have attached the GeoJSON for reference json.txt
> <http://osgeo-org.1560.x6.nabble.com/file/n5088434/json.txt>  !
> Thanks in advance!
> Thanks
> Aditya Kumar
> GIS Developer
> http://osgeo-org.1560.x6.nabble.com/WFS-with-both-point-and-polygon-features
> -tp5088434.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
> Users mailing list
> End of Users Digest, Vol 86, Issue 11
