[OpenLayers-Users] Open layers proxy problem
Phil Scadden p.scadden at gns.cri.nz
Wed Nov 27 20:19:03 PST 2013
> Hi Phil,
>    Attached is the proxy.cgi file i am using.
> Aditya Kumar proxy.cgi
> <http://osgeo-org.1560.x6.nabble.com/file/n5091588/proxy.cgi>
Hopefully someone more famliar than me with CGI will look. But, does it
work if you just test it as a URL? Do you get the requested URL? If not,
is CGI enabled on the apache server (it is not by default). jsp is
easily debugged in netbeans or eclipse. Presumbly you can do similar
with python. The script would also imply (#!/usr/bin/python) that you
are running this on a unix/linux server (ie not windows). Is this so?
Notice: This email and any attachments are confidential.
If received in error please destroy and immediately notify us.
Do not copy or disclose the contents.
