[OpenLayers-Users] ExtJS 4 Class system and Openlayers
Meine Toonen meinetoonen at b3partners.nl
Wed Oct 9 05:05:26 PDT 2013
I think this belongs more to the sencha forums, but here it goes.
For the feature info:
When creating the grid for the featureinfo you can do something like this:
var grid = Ext.create(Ext.grid.Panel, {/* options */ });
When loading new data, you reference the grid variable:
var store = grid.getStore();
store.load();
For the treepanel:
I don't know if this has to do with the new class system, but for the listener to be aware of the global scope, you have to set this. Like:
listeners: {
    checkchange: function(node, check) {
    scope:this
You can also look up the nodes itself, instead of setting them as globals. Explanation here: http://stackoverflow.com/questions/13139150/select-treepanel-node-by-id
I don't know why .setVisiblity() is undefined for layer1,layer2, etc. For that I have to know how you store them (and thus what kind of object they are).
You problems have little to nothing to do with openlayers, and more with extjs.
I hope that helps!
Kind regards!
Met vriendelijke groet,
Meine Toonen
B3Partners BV
Tel: 030 214 2083
  _____
To: openlayers-users at lists.osgeo.org
Sent: Wed, 09 Oct 2013 13:14:37 +0100
Subject: [OpenLayers-Users] ExtJS 4 Class system and Openlayers
Hi everyone,
  I am having problems with integrating Openlayers and ExtJS 4. I had no
  problems with embeding map within ExtJS panel. I have troubles with
  following features:
  Feature info - I can catch map click and I get based on the coordinates data
  in json format. Store, model and grid are configured correctly because it
  works on a local json file. On a map click store should be reloaded. It
  should probably be reloaded from click handler defined in a file where I
  defined OL app and click event but I don't know how because of new class
  system of ExtJS 4, i.e. how should I reference store and how should I call
  .load() method
  Tree panel - layer swithcher - with this one problem is following: Firebug
  first reported that it cannot see variables layer1, layer2 and layer3. I
  defined as global in my olApp.js file. Next, error occured that stated:
  method setVisibility() is not defined. Question: How can I call any method
  defined in Openlayers from ExtJS when using MVC architecture with new ExtJS
  4 class system?
   Ext.define('app.view.LayerSwitcherTreePanel', {
    extend: 'Ext.tree.Panel',
    alias: 'widget.layerSwitcherTreePanel',
    title: 'Layers',
    listeners: {
      if (node.get('id') == 'layer1') {
       layer1.setVisibility(true);
       layer2.setVisibility(false);
       layer3.setVisibility(false);
      } else if (node.get('id') == 'layer2') {
       layer1.setVisibility(false);
       layer2.setVisibility(true);
      } else if (node.get('id') == 'layer3') {
       layer3.setVisibility(true);
    root: {
     text:'All layers',
     expanded:true,
     children:[{
      text: 'Layer set 1',
      expanded: true,
      children: [{
       text: 'Layer 1',
       leaf: true,
       checked: true
       text: 'Layer 2',
       leaf: true,
       checked: false
       text: 'Layer 3',
       leaf: true,
       checked: false
      text:'Layer set 2',
      expanded: true,
      children:[{
       text:'Layer xyz',
       leaf:true,
       checked: true
  To summarize, I have a feeling that only problem with my application is
  visibility of method and variables accross two JS frameworks.
  I hope that everything I wrote is more or less clear. If not or if
  additional code is required please let me know.
  Cheers
  Sasa
  View this message in context: http://osgeo-org.1560.x6.nabble.com/ExtJS-4-Class-system-and-Openlayers-tp5082576.html
  Users mailing list
  Users at lists.osgeo.org
  http://lists.osgeo.org/mailman/listinfo/openlayers-users
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20131009/ba2f949b/attachment.html>
