[OpenLayers-Users] Why Filter do not work ?
emrecio emreciolopez at gmail.com
Sat Oct 19 04:19:41 PDT 2013
I've been facing with the same problem.
I've found that when you set in "property"  in one of the filters a field
which isn't a char field is when the combination of the multiple filters
doesn't work, and only works the filter with has a non-char field.
The question now is, what can we do to make it works with char and non-char
fields...
View this message in context: http://osgeo-org.1560.x6.nabble.com/Why-Filter-do-not-work-tp3918969p5084591.html
