[OpenLayers-Users] problem with Mapguide tiled map on EPSG:21781
Franz1965 fsozzi at INTERCAD.CH
Sat Feb 1 16:44:59 PST 2014
Hi everybody,
I have no problem with OpenLayers sample on Mapguide if I execute on
Sheboygan, bot tiled and not tiled.
I have no problems if I convert this sample on my project on EPSG:21781 on
not-tiled version.
But tiled map does not display. I can display tiled map on AjaxViewer or
Maestro, but not on OpenLayers.
Any idea?...
Best regards
//tiled version
function initTiled(){
        var extent = new
OpenLayers.Bounds(562985.576,158127.222,568066.399,165643.041);
        var tempScales = [35000,15000,5000,1500,500,200,100];
        var mapOptions = {
                maxExtent: extent,
                scales: tempScales
        map = new OpenLayers.Map( 'map', mapOptions );
        var params = {
          mapdefinition:
'Library://INFOGEO/MyProject/Default.MapDefinition',
          basemaplayergroupname: "Base Layer Group"
        var options = {
          singleTile: false
        var layer = new OpenLayers.Layer.MapGuide( "MapGuide OS tiled
layer", url, params, options );
        map.addLayer(layer);
        map.zoomToMaxExtent();
//un-tiled version
function initUntiled() {
  var extent = new
  var mapOptions = {
                units: 'm',
                projection: 'EPSG:21781',
                maxExtent: extent,
                maxResolution: 'auto',
                controls: []
  map = new OpenLayers.Map( 'map2', mapOptions );
        map.addControl(new OpenLayers.Control.NavToolbar());
        map.addControl(new OpenLayers.Control.PanZoom());
        map.addControl(new OpenLayers.Control.NavigationHistory());
  var options = {
          isBaseLayer: true,
          transitionEffect: "resize",
          buffer: 1,
          useOverlay: false,
          useAsyncOverlay: false,
          singleTile: true
  var params = {
          mapdefinition: 'Library://INFOGEO/MyProject/Default.MapDefinition'
  var layer = new OpenLayers.Layer.MapGuide( "MapGuide OS untiled
baselayer", url, params, options );
        map.addControl(new OpenLayers.Control.LayerSwitcher());
View this message in context: http://osgeo-org.1560.x6.nabble.com/problem-with-Mapguide-tiled-map-on-EPSG-21781-tp5101388.html
