[OpenLayers-Users] OpenLayers do not detect Proj4js
Bart van den Eijnden bartvde at boundlessgeo.com
Tue Feb 11 10:10:54 PST 2014
My guess here is that OpenLayers 2.10 is not compatible with Proj4js 2.X. Try Proj4js 1.1 instead.
Best regards,
Bart
Front-end Developer | Boundless
@boundlessgeo
On 11 Feb 2014, at 17:58, Juanma M. R. <juanma.mr at gmail.com> wrote:
> Hi,
> Thank you Robert. I already included a file with the CRS like that:
> <script TYPE="text/javascript" src="proj4js-2.1.0/lib/proj4.js"></script>
> <script TYPE="text/javascript" src="proj4js-2.1.0/lib/spider_srs.js"></script>
> <script TYPE="text/javascript" src="OpenLayers-2.10/OpenLayers.js"></script>
> with one line for each CRS like the ones from spatialreference.org:
> Proj4js.defs["EPSG:900913"] = "+proj=merc +a=6378137 +b=6378137 +lat_ts=0.0 +lon_0=0.0 +x_0=0.0 +y_0=0 +k=1.0 +units=m +nadgrids=@null +wktext  +no_defs";
> Proj4js.defs["EPSG:4230"] = "+proj=longlat +ellps=intl +no_defs";
> and it thorughs the error:
> "ReferenceError: Proj4js is not defined"
> The object Proj4js is not defined but the proj4.js file gives no error. Am I using a wrong object name for including the defs strings?
> Cheers,
> Juan Manuel Moreno Rivera.
> Sección de Teledetección y SIG / Remote Sensing & GIS group
> Instituto de Desarrollo Regional / Institute for Regional Development
> Universidad de Castilla-La Mancha / University of Castilla-La Mancha
> Tlf: +34 967599200 (Ext: 2623)
> http://www.teledeteccionysig.es/
> 2014-02-07 1:35 GMT+01:00 Robert Sanson <Robert.Sanson at asurequality.com>:
> Hi Juan
> You are missing the .js file name in the first <script></script> block.
> Here is some code that works for me:
> <script src="lib/proj4js-compressed.js"></script>
> <script src="lib/EPSG2193.js"></script>
> <script src="lib/EPSG4326.js"></script>
> <script src="OpenLayers.js"></script>
> <script type="text/javascript">
> var xys = map.getLonLatFromViewPortPx(e.xy);
>       easting = xys.lon;
>       northing = xys.lat;
>        var tempgeom = new OpenLayers.Geometry.Point(easting,northing);
>       //now re-projection to WGS84
>       var src = new OpenLayers.Projection('EPSG:2193');
>       var dest = new OpenLayers.Projection('EPSG:4326');
>       OpenLayers.Projection.transform(tempgeom, src, dest);
> regards,
> Robert
> >>> "Juanma M. R." <juanma.mr at gmail.com> 7/02/2014 3:23 a.m. >>>
> Dear list,
> I am trying to reproject in client side using OpenLAyers but I have
> problems to find how to make OpenLayers detecting Proj4js. The proj
> The source code for including OpenLayers and Proj4js is:
> <script TYPE="text/javascript" src="proj4js-2.1.0/dist/"></script>
> The source code for reprojecting is:
> olb = new OpenLayers.Bounds(b.minx,b.miny,b.maxx,b.maxy);
> var srcprj = new OpenLayers.Projection("EPSG:23030");
> var destprj = new OpenLayers.Projection("EPSG:900913"); //A definition of
> newOlb = olb.transform(srcprj, destprj);
> The OpenLayers.Projection method creates a Projection object but the proj
> instance, the property of Projection type, is null in both cases. So I
> imagine it is not capable of creating it. I have the documentation but
> maybe I am missing something so obvious ... the final result is that the
> coordinates of the new bounds are a copy of the original ones.
> The other question is how to declare the "EPSG:900913". I have included a
> file with the Proj4js.defs for each EPSG code to be included but when I add
> the line to include this .js content it teels me that Proj4js is not an
> object.
> So, I am doing something wrong integrating the proj4js and OpenLayers.
> Could anyone help me? Just pointing to the right docummentation to
> configure OpenLayers with Proj4js (I have already tried copying proj4js in
> the same folder as OpenLayers.js but t didn't work).
> Cheers,
> This email and any attachments are confidential and intended solely for the addressee(s). If you are not the intended recipient, please notify us immediately and then delete this email from your system.
> This message has been scanned for Malware and Viruses by Websense Hosted Security.
> www.websense.com
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20140211/fea71286/attachment.html>
