[OpenLayers-Users] load TMS cache data in openlayers
pankaj123 pankaj.bansal.jiit at gmail.com
Tue Jan 7 10:47:31 PST 2014
Hi this is in continuation from my question on geoserver mailing list
http://osgeo-org.1560.x6.nabble.com/Using-TMS-cache-data-td5096545.html#a5096831
This is my question
I tried using TMS cache without geoserver. I did put the data on apache
server and was able to see some images being loaded. but I am having some
problem
1. What is the url I am supposed to provide. I saw the openlayers example
and its giving url of some .py file which in turn is providing url of
another .py file which have timeserver info. I have a TMS cache data and a
.xml file which gives info about that data. So am I suppopsed to give path
of .xml file. When I tries that, it starts looking for tiles in url  which
has .xml path like its a folder like
*If I set the url to    http://localhost:81/DodaMissing/tms.xml/
layerName to         DodaMissing *
It starts lokking for tiles in urls which look like
*http://localhost:81/DodaMissing/tms.xml/1.0.0/DodaMissing/5/20/13.png*
This has the .xml fileName in url. Data can't be in this folder.
Is it wrong. What should I do
2. So I gave a
url as                 http://localhost:81/
layerName as       DodaMissing
openlayers starts looking for tiles in
http://localhost:81/1.0.0/DodaMissing/5/12/18.png
I have copied my in this path, sopit is able to load some tiles.
Thing is I dont have all the data. The info about data is only in .xml but
as now I am giving path of folder, openlayers starts lookinig tiles which
are not present.
Also I am not able to provide srs as EPSG:4326, so I saw as I tries zoominig
in out at location whose data I  have, It was trying to access something
like
http://localhost:81/1.0.0/DodaMissing/15/23262/19579.png
but I had data like http://localhost:81/1.0.0/DodaMissing/15/46479/22396.png
which means their is lot of difference in 'X' coordinate.
Is that a problem. I think I am not specifying SRS anywhere. Can this be
because of that.
I am copying the .xml content here, so you guys can see.
<?xml version="1.0"?>
<tilemap tilemapservice="" version="">
    <title>
    </title>
    <abstract>
    </abstract>
    <srs>
        epsg:4326
    </srs>
    <boundingbox maxx="180.0000000000000000000000000"
maxy="90.0000000000000000000000000" minx="-180.0000000000000000000000000"
miny="-90.0000000000000000000000000">
    </boundingbox>
    <origin x="-180.0000000000000000000000000"
    </origin>
    <tileformat extension="png" height="256" mime-type="" width="256">
    </tileformat>
    <tilesets profile="global-geodetic">
        <tileset href="" order="0"
units-per-pixel="0.7031250000000000000000000">
        </tileset>
        <tileset href="" order="1"
units-per-pixel="0.3515625000000000000000000">
        </tileset>
        <tileset href="" order="2"
units-per-pixel="0.1757812500000000000000000">
        </tileset>
        <tileset href="" order="3"
units-per-pixel="0.0878906250000000000000000">
        </tileset>
        <tileset href="" order="4"
units-per-pixel="0.0439453125000000000000000">
        </tileset>
        <tileset href="" order="5"
units-per-pixel="0.0219726562500000000000000">
        </tileset>
        <tileset href="" order="6"
units-per-pixel="0.0109863281250000000000000">
        </tileset>
        <tileset href="" order="7"
units-per-pixel="0.0054931640625000000000000">
        </tileset>
        <tileset href="" order="8"
units-per-pixel="0.0027465820312500000000000">
        </tileset>
        <tileset href="" order="9"
units-per-pixel="0.0013732910156250000000000">
        </tileset>
        <tileset href="" order="10"
units-per-pixel="0.0006866455078125000000000">
        </tileset>
        <tileset href="" order="11"
units-per-pixel="0.0003433227539062500000000">
        </tileset>
        <tileset href="" order="12"
units-per-pixel="0.0001716613769531250000000">
        </tileset>
        <tileset href="" order="13"
units-per-pixel="0.0000858306884765625000000">
        </tileset>
        <tileset href="" order="14"
units-per-pixel="0.0000429153442382812500000">
        </tileset>
        <tileset href="" order="15"
units-per-pixel="0.0000214576721191406250000">
        </tileset>
        <tileset href="" order="16"
units-per-pixel="0.0000107288360595703130000">
        </tileset>
        <tileset href="" order="17"
units-per-pixel="0.0000053644180297851563000">
        </tileset>
        <tileset href="" order="18"
units-per-pixel="0.0000026822090148925781000">
        </tileset>
        <tileset href="" order="19"
units-per-pixel="0.0000013411045074462891000">
        </tileset>
    </tilesets>
</tilemap>
PS. We are able to see this TMS cache data in OSGEarth...So data is not
corrupt or anything..
Any help...
Regards
Pankaj Bansal
View this message in context: http://osgeo-org.1560.x6.nabble.com/load-TMS-cache-data-in-openlayers-tp5096837.html
