[OpenLayers-Users] OpenLayers and IE11 wfs
Bart van den Eijnden bartvde at boundlessgeo.com
Wed Jan 8 11:06:06 PST 2014
Confirmed this as an OpenLayers issue.
See: https://github.com/openlayers/openlayers/pull/1220 for a fix.
Best regards,
Bart
Front-end Developer | Boundless
@boundlessgeo
On 11 Dec 2013, at 11:07, Bart van den Eijnden <bartvde at boundlessgeo.com> wrote:
> There seem to be bugs in IE11 XML implementation see also: http://connect.microsoft.com/IE/feedback/details/800941/ie11-rtm-not-correctly-giving-namespace-attributes-with-setattributens
> So not sure as yet that this is an OpenLayers issue.
> Best regards,
> Bart
> @boundlessgeo
> On 10 Dec 2013, at 17:35, Ralph Dell <RDell at CatawbaCountyNC.gov> wrote:
>> A few weeks ago I posted a problem that I was having with IE11, didn't hear anything back and was able to code an awkward work around for my specific issue
>> https://www.mail-archive.com/openlayers-users@lists.osgeo.org/msg11768.html
>> Well yesterday I realized I was having a similar issue with the GetFeature control
>> I found this solution on the OpenLayers developer list. Thank you Stephen Battey. I am posting it here to make the answer more widely available
>> http://osgeo-org.1560.x6.nabble.com/WFS-and-IE-11-td5090636.html
>> We override the write method in the OpenLayers.Format.XML class. After the XML has been generated we do a search-replace on the rogue text in the XML namespace.
>> Here is the code we run after OpenLayers has loaded:
>> var _class = OpenLayers.Format.XML;
>> var originalWriteFunction = _class.prototype.write;
>> var patchedWriteFunction = function()
>>         var child = originalWriteFunction.apply( this, arguments );
>>         // NOTE: Remove the rogue namespaces as one block of text.
>>         //       The second fragment "NS1:" is too small on its own and could cause valid text (in, say, ogc:Literal elements) to be erroneously removed.
>>         child = child.replace( new RegExp( 'xmlns:NS1="" NS1:', 'g' ), '' );
>>         return child;
>> _class.prototype.write = patchedWriteFunction;
>> Ralph Dell
>> Users mailing list
>> Users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/openlayers-users
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20140108/8c1de3ad/attachment.html>
