[OpenLayers-Users] Print issue with Openlayers 2.12 using Mapfish client
saliniopenlayer salini.sudhakaran at experionglobal.com
Sun Jan 12 22:38:52 PST 2014
Hi
I am having issues while printing maps(using Mapfish print) with OSM as the
base layer. I'm using geoext 1.1, openlayers 2.12, geoserver 2.1.1. When i
tried the same with openlayers 2.11, print is working fine. The issue is
getting only when openlayers 1.12 is using. Please check the error below.
Error while generating PDF:
DocumentException: org.mapfish.print.InvalidJsonValueException:
spec.layers[0].baseURL has an invalid value:
http://a.tile.openstreetmap.org/ (spec.layers[0].baseURL has an invalid
value: http://a.tile.openstreetmap.org/)
View this message in context: http://osgeo-org.1560.x6.nabble.com/Print-issue-with-Openlayers-2-12-using-Mapfish-client-tp5097637.html
