[OpenLayers-Users] Print problem using maxGetUrlLength and HTTP POST
Glenn Mullett GMullett at lidwala.com
Fri Jan 17 07:47:22 PST 2014
Hi Sven
If you're using Apache2, you can try configuring the server to allow long URLs:
In your VirtualHost config (e.g. in httpd.conf), set LimitRequestFieldSize and LimitRequestLine to something big.
e.g.
<VirtualHost *:80>
        LimitRequestFieldSize 50000
        LimitRequestLine 50000
           #....etc....#
</VirtualHost>
Regards,
Glenn
On 17/01/14 17:15, Sven Schroeter wrote:
I'm using the maxGetUrlLength property of the layer's tileOptions option to
send a layer request via post to a custom WMS-Script.
This works fine for me, but I'm not able to print a map with this layers
using HTTP POST (with no browser).
You can test this problem on the example "WMS with POST Requests to Avoid
Long URLs"
http://dev.openlayers.org/releases/OpenLayers-2.13.1/examples/wms-long-url.h
tml
If you use  Long URL - POST requests you can't print the map
If you use Short URL - GET requests it's no problem.
Any idea to solve this problem?
Greetings
Sven
Users mailing list
Users at lists.osgeo.org<mailto:Users at lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/openlayers-users
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20140117/c56c169b/attachment.html>
