[OpenLayers-Users] Issue with WMSGetFeatureInfo Control
Jerome A. Wendell jawendell at suddenlink.net
Thu Jul 3 20:46:01 PDT 2014
Phil,
Thanks again for your reply.  I checked the NET tab of the debugger and I
still was not sure about the source of the problem.  But, you got me to
thinking and I setup a test between GeoServer 2.4.3 and 2.5.1.  Sure enough,
the problem did not exist in GeoServer 2.4.3.  I did some searching on the
changes in 2.5.1, and I found the bug report below:
http://jira.codehaus.org/i#browse/GEOS-6420
The problem that I was having is not the same as in the bug report, but the
recommendation of adding
-Dorg.geoserver.wms.featureinfo.render.enabled=false to the JVM startup
parameters to revert back to the old GetFeatureInfo engine resolved my
problem for now.  I need to do some additional research to determine why the
new GetFeatureInfo engine was causing me problems, but at least I have the
control working correctly now.
I always appreciate your input, and you seem to always get me back on the
right track.
Thanks,
Jerome Wendell
-----Original Message-----
[mailto:openlayers-users-bounces at lists.osgeo.org] On Behalf Of Phil Scadden
Sent: Thursday, July 03, 2014 7:00 PM
To: openlayers-users at lists.osgeo.org
Subject: Re: [OpenLayers-Users] Issue with WMSGetFeatureInfo Control
No answers but a strategy to tie down the issue: I would look at the request
that OL emitted when you clicked in the NET tab of the debugger that
resulted in the wrong hit. If the request is what you expect (what it sends
to geoserver should only return one polygon), then I suggest take it up with
geoserver list, giving them the request data. If OL has unnecessarily
expanded the request parameters, then its a problem with OL. Post the
request data here and lets look at it.
Notice: This email and any attachments are confidential.
If received in error please destroy and immediately notify us.
Do not copy or disclose the contents.
Users mailing list
 <mailto:Users at lists.osgeo.org> Users at lists.osgeo.org
 <http://lists.osgeo.org/mailman/listinfo/openlayers-users>
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20140703/54e5a827/attachment.html>
