[OpenLayers-Users] POST not implemented
pablo zader pzader at gmail.com
Mon Jul 28 07:27:04 PDT 2014
Hi list,
I'm developing a client wps modifying the example WPSDemo.js from
http://suite.opengeo.org/4.1/processing/wpsclient/index.html .
I'm using zoo-proyect as wps server.
I'm trying to invoke the buffer process implemented in GRASS GIS gives me
the following error:
POST
http://localhost:9080/proxy/?url=http%3A%2F%2Flocalhost%2Fcgi-bin%2Fzoo_loader.cgi%3F
501 (Not Implemented)
The query POST is:
<wps:Execute xmlns:wps="http://www.opengis.net/wps/1.0.0" version="1.0.0"
service="WPS" xsi:schemaLocation="http://www.opengis.net/wps/1.0.0
http://schemas.opengis.net/wps/1.0.0/wpsAll.xsd" xmlns:xsi="
http://www.w3.org/2001/XMLSchema-instance"><ows:Identifier xmlns:ows="
http://www.opengis.net/ows/1.1">v_buffer</ows:Identifier><wps:DataInputs><wps:Input><ows:Identifier
xmlns:ows="http://www.opengis.net/ows/1.1">input</ows:Identifier><ows:Title
xmlns:ows="http://www.opengis.net/ows/1.1">Or data source for direct OGR
access</ows:Title><wps:Data><wps:ComplexData
mimeType="text/xml"><![CDATA[<wfs:FeatureCollection xmlns:wfs="
http://www.opengis.net/wfs"><gml:featureMember xmlns:gml="
http://www.opengis.net/gml"><feature:features xmlns:feature="
http://mapserver.gis.umn.edu/mapserver"
fid="OpenLayers_Feature_Vector_248"><feature:geometry><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates
decimal="." cs="," ts=" ">-6383273.5489707,1396657.4552779
-4230806.8327598,26905.908598173 -6246298.3943028,-442723.19312058
-6383273.5489707,1396657.4552779</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></feature:geometry></feature:features></gml:featureMember></wfs:FeatureCollection>]]></wps:ComplexData></wps:Data></wps:Input><wps:Input><ows:Identifier
xmlns:ows="http://www.opengis.net/ows/1.1">layer</ows:Identifier><ows:Title
xmlns:ows="http://www.opengis.net/ows/1.1">A single vector map can be
connected to multiple database tables. This number determines which table
to use. When used with direct OGR access this is the layer
name.</ows:Title><wps:Data><wps:LiteralData/></wps:Data></wps:Input><wps:Input><ows:Identifier
xmlns:ows="http://www.opengis.net/ows/1.1">cats</ows:Identifier><ows:Title
xmlns:ows="http://www.opengis.net/ows/1.1">Example:
1,3,7-9,13</ows:Title><wps:Data><wps:LiteralData/></wps:Data></wps:Input><wps:Input><ows:Identifier
xmlns:ows="http://www.opengis.net/ows/1.1">where</ows:Identifier><ows:Title
xmlns:ows="http://www.opengis.net/ows/1.1">Example: income 1000 and inhab
10000</ows:Title><wps:Data><wps:LiteralData/></wps:Data></wps:Input><wps:Input><ows:Identifier
xmlns:ows="http://www.opengis.net/ows/1.1">type</ows:Identifier><ows:Title
xmlns:ows="http://www.opengis.net/ows/1.1">Feature
type</ows:Title><wps:Data><wps:LiteralData/></wps:Data></wps:Input><wps:Input><ows:Identifier
xmlns:ows="http://www.opengis.net/ows/1.1">distance</ows:Identifier><ows:Title
xmlns:ows="http://www.opengis.net/ows/1.1">Buffer distance along major axis
in map
units</ows:Title><wps:Data><wps:LiteralData>195678.7923828125</wps:LiteralData></wps:Data></wps:Input><wps:Input><ows:Identifier
xmlns:ows="http://www.opengis.net/ows/1.1">minordistance</ows:Identifier><ows:Title
xmlns:ows="http://www.opengis.net/ows/1.1">Buffer distance along minor axis
in map
units</ows:Title><wps:Data><wps:LiteralData/></wps:Data></wps:Input><wps:Input><ows:Identifier
xmlns:ows="http://www.opengis.net/ows/1.1">angle</ows:Identifier><ows:Title
xmlns:ows="http://www.opengis.net/ows/1.1">Angle of major axis in
degrees</ows:Title><wps:Data><wps:LiteralData/></wps:Data></wps:Input><wps:Input><ows:Identifier
xmlns:ows="http://www.opengis.net/ows/1.1">bufcolumn</ows:Identifier><ows:Title
xmlns:ows="http://www.opengis.net/ows/1.1">Name of column to use for buffer
distances</ows:Title><wps:Data><wps:LiteralData/></wps:Data></wps:Input><wps:Input><ows:Identifier
xmlns:ows="http://www.opengis.net/ows/1.1">scale</ows:Identifier><ows:Title
xmlns:ows="http://www.opengis.net/ows/1.1">Scaling factor for attribute
column
values</ows:Title><wps:Data><wps:LiteralData/></wps:Data></wps:Input><wps:Input><ows:Identifier
xmlns:ows="http://www.opengis.net/ows/1.1">tolerance</ows:Identifier><ows:Title
xmlns:ows="http://www.opengis.net/ows/1.1">Maximum distance between
theoretical arc and polygon segments as multiple of
buffer</ows:Title><wps:Data><wps:LiteralData/></wps:Data></wps:Input><wps:Input><ows:Identifier
xmlns:ows="http://www.opengis.net/ows/1.1">-s</ows:Identifier><ows:Title
xmlns:ows="http://www.opengis.net/ows/1.1">Make outside corners
straight</ows:Title><wps:Data><wps:LiteralData/></wps:Data></wps:Input><wps:Input><ows:Identifier
xmlns:ows="http://www.opengis.net/ows/1.1">-c</ows:Identifier><ows:Title
xmlns:ows="http://www.opengis.net/ows/1.1">Dont make caps at the ends of
polylines</ows:Title><wps:Data><wps:LiteralData/></wps:Data></wps:Input><wps:Input><ows:Identifier
xmlns:ows="http://www.opengis.net/ows/1.1">-t</ows:Identifier><ows:Title
xmlns:ows="http://www.opengis.net/ows/1.1">Transfer categories and
attributes</ows:Title><wps:Data><wps:LiteralData/></wps:Data></wps:Input></wps:DataInputs><wps:ResponseForm><wps:RawDataOutput
mimeType="text/xml"><ows:Identifier xmlns:ows="
">output</ows:Identifier></wps:RawDataOutput></wps:ResponseForm></wps:Execute>
Thanks in advanced
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20140728/a9c1bbbd/attachment-0001.html>
