[OpenLayers-Users] POST not implemented
Bart van den Eijnden bartvde at boundlessgeo.com
Tue Jul 29 22:43:20 PDT 2014
Small correction Phil, GET does use the proxy if it's XHR and not on the same origin.
Bart
Sent from my iPhone
> On 30 jul. 2014, at 06:46, Phil Scadden <p.scadden at gns.cri.nz> wrote:
>> I'm using the OpenGeo suite with GeoExplorer as client.  In the file composer.html is setting   proxy: "../proxy/?url=" and works well. I can also make DescribeProcess queries using GET method but when I do an EXECUTE request using POST method is not working.
>> if I change proxy settings to some of these /proxy/proxy.cgi?url=xxxx or /proxy.cgi?url=xxxx stop operating the query using GET DescribeProcess.
> Sorry, I dont know the OpenGeo suite or Geoexplorer, it might best to take it up with them.
> GET doesnt use the proxy - doesnt need to. You need the proxy to deal with cross-origin security issues when using XHR. (ajax). if ProxyHost="/proxy..." this implies you have a /proxy context on the server. "../proxy" looks more likely - but /proxy/?url doesnt look like a valid syntax. Is there a proxy directory or script at the same level as your main html on the server?
> The important thing is to look at your server set up. See where the proxy code actually is, what it is, and then make sure the client matches it. It is common to use cgi with Apache but I know next to nothing about this as deploy with tomcat and use a jsp for proxy.
> Notice: This email and any attachments are confidential. If received in error please destroy and immediately notify us. Do not copy or disclose the contents.
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20140730/c6120ef4/attachment-0001.html>
