[OpenLayers-Users] KML Style and Label Question
Xavier Mamano (jorix)
xavier.mamano at gmail.com
Wed Mar 19 17:03:07 PDT 2014
> ... KML and set the format to extract styles, the style map on the vector
label is bypassed. Is this true?
Yes :-(
> If so, how do you extract styling AND set a label on a feature?
You consider acceptable to use <LabelStyle> in KLM? If not, AFAIK, should do
some trick in function KML.parseStyle
Regards,
dnbphysicist wrote
> All, it seems when you plot KML and set the format to extract styles, the
> style map on the vector label is bypassed. Is this true? If so, how do you
> extract styling AND set a label on a feature? Using OL 2.12.
> Thanks in advance.
> Users mailing list
> Users at .osgeo
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
View this message in context: http://osgeo-org.1560.x6.nabble.com/KML-Style-and-Label-Question-tp5129659p5130001.html
