[OpenLayers-Users] Too many layers?
Martin Davis mtnclimb at gmail.com
Thu Sep 18 10:49:21 PDT 2014
This can be done by creating a new LayerSwitcher control which supports
grouping of layers.  This isn't too hard to do, if you have sufficient JS
and HTML coding abilty.
There's an open pull request for a new LayerSwitcherGroups control that
apparently does this:
https://github.com/openlayers/openlayers/pull/12/
On Wed, Sep 17, 2014 at 10:51 PM, Andreas Forø Tollefsen <
andreasft at gmail.com> wrote:
> Hi,
> I am working on a thematic mapping platform showing data at local
> administrative levels.
> I have many layers, so I run into problems (see screenshot:
> http://gisintersect.com/many_layers.png).
> Is there any way I can collapse groups of layers within the layer switcher?
> I have a high number of layers, as you can see in the switcher. Hence, I
> need some way to collapse/group/categorize the layers, so that I do not
> need to show all of them in the layerswitcher at once.
> The result is that layers drop outside the map, so either, there is a
> maximum number of layers, or there should be a better way to do it.
> Andreas
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20140918/1b3b7ce8/attachment.html>
