[OpenLayers-Users] Showing points from a database
Arnd Wippermann arnd.wippermann at web.de
Sun Sep 21 10:19:32 PDT 2014
your map is in projection EPSG:900913 (OSM).
Are your data also in this projection or perhaps in EPSG:4326 (lonlat)?
If so, it could be that your data are shown (at x=0,y=0), but you only can't
see them.
Regards,
Arnd
  _____
Von: openlayers-users-bounces at lists.osgeo.org
[mailto:openlayers-users-bounces at lists.osgeo.org] Im Auftrag von Niccolò Dal
Santo
Gesendet: Freitag, 19. September 2014 23:11
An: Mark Prins
Cc: openlayers-users
Betreff: Re: [OpenLayers-Users] Showing points from a database
Thank you very much for your answer. I have therefore started to investigate
the possiblity to use the GeoJSON format, and now I am trying to train with
this format with this example but it doesn't work
    <script type="text/javascript">
    var map = new OpenLayers.Map("my_map");
    var layer = new OpenLayers.Layer.OSM("OpenStreetMap");
    map.addLayer(layer);
    map.addControl(new OpenLayers.Control.LayerSwitcher());
    map.setCenter(new OpenLayers.LonLat(0,0), 2);
    var citiesLayer = new OpenLayers.Layer.Vector("World Cities (GeoJSON)",
        {   protocol: new OpenLayers.Protocol.HTTP({
            url: "http://localhost/openlayers/world_cities.json",
            format: new OpenLayers.Format.GeoJSON()
        strategies: [
            new OpenLayers.Strategy.Fixed(),
            new OpenLayers.Strategy.Cluster({distance: 15})
    map.addLayer(citiesLayer);
</script>
In order to make the protocol work I have installed nginx on my laptop and
the url correctly points to the file world_cities.json in my browser. Anyway
this example doesn't work, any idea why?
Thanks!
Niccolò
2014-09-19 15:54 GMT+02:00 Mark Prins <mc.prins at gmail.com>:
using plain text or (geo) json is much less error prone than using
GML, and probably gives better performance
2014-09-19 15:45 GMT+02:00 Niccolò Dal Santo <ncl.dalsanto at gmail.com>:
> Hi there,
> I am new of Openlayers and I need to show some points that come from a
> database on a map centred in Turin (Italy), with some information related
to
> this point (for instance an image). Searching on line I have found that
> Openlayers supports many formats of data like GML, KML, GeoJSON and many
> others. Could you suggest a format useful fror my problem and maybe some
> examples of how to use it?
> I have tried with this code generating a map of europe, but it doesn't
work
> <html>
> <head>
>   <title>Prova GML</title>
>     <script src="http://openlayers.org/api/OpenLayers.js"></script>
> </head>
>     <body>
>     <div id="ch3_gml" style="width: 100%; height: 100%;"></div>
>         // Create the map using the specified DOM element
>         var map = new OpenLayers.Map("ch3_gml");
>         map.addLayer(new OpenLayers.Layer.Vector("Europe (GML)", {
>                 url: "./europe.gml",
>                 format: new OpenLayers.Format.GML()
>             strategies: [new OpenLayers.Strategy.Fixed()]
>     </script>
> </body>
> </html>
> where europe.gml is a gml file in the same folder of this script, but
> nothing happens.
> Thank you very much for your help!
> Regards
> Niccolò
> Niccolò Dal Santo
> +39 342 15 70 842 <tel:%2B39%20342%2015%2070%20842>
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
Disclaimer;
This message is just a reflection of what I thought at the time of
sending. The message may contain information that is not intended for
you or that you don't understand.
Users mailing list
Niccolò Dal Santo
+39 342 15 70 842
Diese E-Mail ist frei von Viren und Malware, denn der avast! Antivirus Schutz ist aktiv.
http://www.avast.com
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20140921/ddf43ee6/attachment.html>
