[OpenLayers-Users] Showing points from a database
Arnd Wippermann arnd.wippermann at web.de
Mon Sep 22 11:25:41 PDT 2014
Hi Niccolò,
if your vector data is in EPSG:4326, then you have to declare the projection
of the data in the options of your vector layer:
        map.addLayer(new OpenLayers.Layer.Vector("Continents (GML)", {
            protocol: new OpenLayers.Protocol.HTTP({
                url:
"../OL210/MapServer_WFS_Demo/MapServer_SHP/simple_continents.gml",
                format: new OpenLayers.Format.GML()
            projection:new OpenLayers.Projection("EPSG:4326"),   //<--
projection of the data, if not the same as the map
            attribution:'<a href="/OLClient/extension/OLClient Object
Browser.asp" target="OLCOB">Object Browser</a>',
            strategies: [new OpenLayers.Strategy.Fixed()]
see
http://gis.ibbeck.de/ginfo/apps/OLExamples/OLdev/prova_gml_dev.asp
Good Luck, Arnd
  _____
Von: Niccolò Dal Santo [mailto:ncl.dalsanto at gmail.com]
Gesendet: Sonntag, 21. September 2014 19:50
An: arnd.wippermann at web.de
Cc: openlayers-users
Betreff: Re: [OpenLayers-Users] Showing points from a database
At first ,thanks a lot for the help.
Secondly, I don't know since this is an example downloaded by the internet.
However I have tried by inserting this line in my code
    map.setCenter(
        new OpenLayers.LonLat(0,0).transform(
            map.getProjectionObject()
        ), 1
So, this is my final code:
<html>
<head>
  <title>Prova GML</title>
    <script src="http://openlayers.org/api/OpenLayers.js"></script>
</head>
    <body>
<div id="ch3_cluster" style="width: 100%; height: 100%;"></div>
    <script type="text/javascript">
    var map = new OpenLayers.Map("ch3_cluster");
    var layer = new OpenLayers.Layer.OSM("OpenStreetMap");
    map.addLayer(layer);
    map.addControl(new OpenLayers.Control.LayerSwitcher());
//    map.setCenter(new OpenLayers.LonLat(0,0), 2);
    map.setCenter(
        ), 1
    // World Cities
    var citiesLayer = new OpenLayers.Layer.Vector("World Cities (GeoJSON)",
        {   protocol: new OpenLayers.Protocol.HTTP({
            url: "http://localhost/world_cities.json",
            format: new OpenLayers.Format.GeoJSON()
        strategies: [
            new OpenLayers.Strategy.Fixed(),
            new OpenLayers.Strategy.Cluster({distance: 15})
    map.addLayer(citiesLayer);
</script>
</body>
</html>
Now I have also tried with another and easier example found in the web but
it doesn't work as well, so I was wondering whether I am missing something
like a basic requirement or a Java updating or whatever in order to use
these features. What I have done is to download the library ( but the source
in this code should be the web as the first script states). Do you have any
idea on that?
Thank you very much!
Niccolò
2014-09-21 19:19 GMT+02:00 Arnd Wippermann <arnd.wippermann at web.de>:
your map is in projection EPSG:900913 (OSM).
Are your data also in this projection or perhaps in EPSG:4326 (lonlat)?
If so, it could be that your data are shown (at x=0,y=0), but you only can't
see them.
Regards,
Arnd
  _____
Von: openlayers-users-bounces at lists.osgeo.org
[mailto:openlayers-users-bounces at lists.osgeo.org] Im Auftrag von Niccolò Dal
Santo
Gesendet: Freitag, 19. September 2014 23:11
An: Mark Prins
Thank you very much for your answer. I have therefore started to investigate
the possiblity to use the GeoJSON format, and now I am trying to train with
this format with this example but it doesn't work
    var map = new OpenLayers.Map("my_map");
            url: "http://localhost/openlayers/world_cities.json",
        strategies: [
</script>
In order to make the protocol work I have installed nginx on my laptop and
the url correctly points to the file world_cities.json in my browser. Anyway
this example doesn't work, any idea why?
Thanks!
Niccolò
2014-09-19 15:54 GMT+02:00 Mark Prins <mc.prins at gmail.com>:
using plain text or (geo) json is much less error prone than using
GML, and probably gives better performance
2014-09-19 15:45 GMT+02:00 Niccolò Dal Santo <ncl.dalsanto at gmail.com>:
> Hi there,
> I am new of Openlayers and I need to show some points that come from a
> database on a map centred in Turin (Italy), with some information related
to
> this point (for instance an image). Searching on line I have found that
> Openlayers supports many formats of data like GML, KML, GeoJSON and many
> others. Could you suggest a format useful fror my problem and maybe some
> examples of how to use it?
> I have tried with this code generating a map of europe, but it doesn't
work
> <html>
> <head>
> </head>
>     <body>
>     <div id="ch3_gml" style="width: 100%; height: 100%;"></div>
>         // Create the map using the specified DOM element
>         var map = new OpenLayers.Map("ch3_gml");
>         map.addLayer(new OpenLayers.Layer.Vector("Europe (GML)", {
>                 url: "./europe.gml",
>     </script>
> </body>
> </html>
> where europe.gml is a gml file in the same folder of this script, but
> nothing happens.
> Thank you very much for your help!
> Regards
> Niccolò
> Niccolò Dal Santo
> +39 342 15 70 842 <tel:%2B39%20342%2015%2070%20842>
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
Disclaimer;
This message is just a reflection of what I thought at the time of
sending. The message may contain information that is not intended for
you or that you don't understand.
Users mailing list
Niccolò Dal Santo
+39 342 15 70 842
  _____
 <http://www.avast.com/>
Diese E-Mail ist frei von Viren und Malware, denn der avast! Antivirus
<http://www.avast.com/>  Schutz ist aktiv.
Niccolò Dal Santo
+39 342 15 70 842
Diese E-Mail ist frei von Viren und Malware, denn der avast! Antivirus Schutz ist aktiv.
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20140922/68a86ff0/attachment-0001.html>
