[OpenLayers-Users] [Possible spoofed sender] Re: [Possible spoofed sender] Re: Like query with "singleChar" does not work correctly in OpenLayers.StyleMap
Ruff, Thomas Thomas.Ruff at solers.com
Mon Apr 27 15:25:55 PDT 2015
filter.value = filter.value.replace(/\*/g, '!*');
From: openlayers-users-bounces at lists.osgeo.org [openlayers-users-bounces at lists.osgeo.org] on behalf of Ruff, Thomas [Thomas.Ruff at solers.com]
Sent: Monday, April 27, 2015 3:25 PM
To: joaorodr84; openlayers-users at lists.osgeo.org
Subject: [Possible spoofed sender] Re: [OpenLayers-Users] [Possible spoofed sender] Re: Like query with "singleChar" does not work correctly in OpenLayers.StyleMap
I messed around with different regex expressions and it seems to work.  I'm no regex expert but maybe the problem is that your query doesn't do what  you think it does.  E.g., I changed it to '[v]' and it correctly colored NV, PA, VT, WV and VA, which are all the 'v' states I can think of.  One thing I noticed is that this line does nothing:
Sent: Monday, April 27, 2015 12:05 PM
Subject: [Possible spoofed sender] Re: [OpenLayers-Users] Like query with "singleChar" does not work correctly in OpenLayers.StyleMap
If you only have one rule then this isn't your problem.  I was just saying don't rely on the order of rules in your sld.  The comparison filters need to be mutually exclusive in my experience.
From: openlayers-users-bounces at lists.osgeo.org [openlayers-users-bounces at lists.osgeo.org] on behalf of joaorodr84 [joaorodr84 at gmail.com]
Sent: Monday, April 27, 2015 11:30 AM
To: openlayers-users at lists.osgeo.org
Subject: Re: [OpenLayers-Users] Like query with "singleChar" does not work correctly in OpenLayers.StyleMap
Hello Ruff Thomas.
As you can see in the example, I use only one rule:
                /* Filter */
                var filter = new OpenLayers.Filter.Comparison({
                    property: 'STATE_NAME',
                    type: OpenLayers.Filter.Comparison.LIKE,
                    value: '.....'
                var wmsFilter = filter.clone();
                /* Rule */
                var rule = new OpenLayers.Rule({
                    filter: filter,
                    symbolizer: {}
I don't think this would be the problem, but please explain your point a
little better.
Thanks a lot
João
View this message in context: https://urldefense.proofpoint.com/v2/url?u=http-3A__osgeo-2Dorg.1560.x6.nabble.com_Like-2Dquery-2Dwith-2DsingleChar-2Ddoes-2Dnot-2Dwork-2Dcorrectly-2Din-2DOpenLayers-2DStyleMap-2Dtp5203061p5203165.html&d=BQIGaQ&c=gpp0UHgwH8jd0f0gRc5QaF0zPfGT1csUQXD9eLov3hQ&r=iiS-4SY2BTp-9WmUwQb3-zEL2tnO_1j_07NMJG-MZ0s&m=oRl6FpNq9nbSCIP50IlpD2TPcY_JAO6w0_z3YgN6LZU&s=rXYpKgX9NgppwlNrQ1Yes6g3KFu-PqnoHwqqGOW6Dbw&e=
Users mailing list
Users at lists.osgeo.org
https://urldefense.proofpoint.com/v2/url?u=http-3A__lists.osgeo.org_mailman_listinfo_openlayers-2Dusers&d=BQIGaQ&c=gpp0UHgwH8jd0f0gRc5QaF0zPfGT1csUQXD9eLov3hQ&r=iiS-4SY2BTp-9WmUwQb3-zEL2tnO_1j_07NMJG-MZ0s&m=oRl6FpNq9nbSCIP50IlpD2TPcY_JAO6w0_z3YgN6LZU&s=83bPUO6ESB8FdW9WJyO719eBaSki0l4mh9cXWjeCE9w&e=
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20150427/cb5744c9/attachment-0001.html>
