[OpenLayers-Users] Problem with WKT reader not reading cloned geometry
Robert Sanson Robert.Sanson at asurequality.com
Wed Mar 25 20:36:49 PDT 2015
Hi
I have a Web mapping app built with OL 2.13.1
Vector data is read in from a database source as WKT. I have to transform from a source projection to a map projection once read into a vector feature, before adding to a vector layer, and then transform back to the source projection when writing out new features or edits back to the database.
My WKT format is defined as:
var wkt_format = new OpenLayers.Format.WKT();
I read my features as:
featgeom = wkt_format.read(crds);
if (srcsrs != mapsrs) {
          featgeom.geometry.transform(srcproj,mapproj);
This works fine.
On writing I get a problem when I clone a feature, reproject it and then try to write out the WKT:
var wkt_out;
        var geometry = feature.geometry.clone();
        geometry.transform(mapproj, srcproj);
        wkt_out = wkt_format.write(geometry);
      else {
        wkt_out = wkt_format.write(feature);
I get an error:
'CLASS_NAME' is null or not an object
WKT.js
Looking in WKT.js it appears the clone is not copying the type of geometry?
     * Method: extractGeometry
     * Entry point to construct the WKT for a single Geometry object.
     * Parameters:
     * geometry - {<OpenLayers.Geometry.Geometry>}
     * Returns:
     * {String} A WKT string of representing the geometry
    extractGeometry: function(geometry) {
        var type = geometry.CLASS_NAME.split('.')[2].toLowerCase();
        if (!this.extract[type]) {
            return null;
        if (this.internalProjection && this.externalProjection) {
            geometry = geometry.clone();
            geometry.transform(this.internalProjection, this.externalProjection);
        var wktType = type == 'collection' ? 'GEOMETRYCOLLECTION' : type.toUpperCase();
        var data = wktType + '(' + this.extract[type].apply(this, [geometry]) + ')';
        return data;
Any clues how to solve this?
Many thanks,
Robert Sanson
This email and any attachments are confidential and intended solely for the addressee(s). If you are not the intended recipient, please notify us immediately and then delete this email from your system.
This message has been scanned for Malware and Viruses by Websense Hosted Security.
www.websense.com
