[OpenLayers-Users] WMS request for dynamic SLD
David Haynes
haynesd2 at gmail.com
Wed Sep 23 08:44:09 PDT 2015
Hello everyone,
I have a question about how to formulate the proper call for this WMS
request. I am using geoserver and PostGIS to publish a raster dataset. I
have made a SLD for this categorical raster that will allow me to turn each
pixel value on an off. The initial style makes the raster completely
transparent as each pixle value opacity is set to '0' and it works fine
when previewing layer through geoserver.
We can take url of the map add on &env=lcwater:1 and the resulting image
looks fine in preview. It only displays water for the entire globe.
However, we have tried unsuccessfully to properly call the wms into any
mapping application (leaflet & openlayers). When the WMS is added to map
only center of base map image is visible. Recapping, I have one layer on
my map, which is supposed to be transparent, and a base layer. The center
is correctly showing the transparency, but edges are not. The SLD is not
working across the map.
However, as the user pans or zooms the SLD updates, makes the map
transparent and they see the base map. My conclusion is that the SLD is not
being consistently applied in all of the raster overviews. Because as you
zoom and pan, different areas become transparent.
However, because this is a global map we always get some non application of
the SLD around +/-180 location. Here raster is always visible.
Something strange is happening in the pyramids. Perhaps the SLD is erroring
when it can not find the values at different pyramid levels, but it works
fine in the geosever preview, so we must be submitting the request
incorrectly. Here is the request we are using.
var ext_world = ol.proj.transformExtent([-180, -65, 180, 90], 'EPSG:4326',
'EPSG:3857')
var mapCenter = ol.proj.transform([0,40], 'EPSG:4326', 'EPSG:3857');
var view = new ol.View({center: mapCenter, zoom: 2, extent:
ext_world});
var map = new ol.Map({target: 'map', renderer: 'canvas', view: view});
var glc_src = new ol.source.TileWMS({
url: '
https://localhost:8080/geoserver/Shoumith/wms?service=WMS&version=1.1.0&request=GetMap&layers=Shoumith:glc_dynamic&styles=&format=application/openlayers
attributions: [new ol.Attribution({html: 'TODO: UPDATE'})],
params: {format: 'image/png', styles:'glc_dynamic'},
var lyr_glc = new ol.layer.Tile({
source: glc_src
glc_src.updateParams({'ENV':'lcwater:1;lcbare:1'})
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20150923/0d1a39f7/attachment.html>
