[OpenLayers-Users] OL3 and kml problem issue on Android 6.0.1
Thomas Gratier osgeo.mailinglist at gmail.com
Sat Sep 3 06:52:32 PDT 2016
Do you serve your HTML via a local server?
If you just put files like that without a web server, you will hit the same
origin policy issue to load KML because of an url call to kml file from an
url like file://your/path/your_index.html
Try a server like https://github.com/NanoHttpd/nanohttpd
Otherwise, try to use this recipe
http://stackoverflow.com/questions/8648616/webview-javascript-cross-domain-from-a-local-html-file
(never tested so no warranty)
Cheers
Thomas Gratier
2016-09-02 14:59 GMT+02:00 ScigallaP <ScigallaP at ibb-bochum.de>:
> Hello,
> I'm new in OL and have an first simple question here.
> My frist small project to show kml files with OL and OSM runs fine on my
> local PC and on a webserver too. The result is shown on desktop (chrome and
> firefox) and mobile browser (chrome and opera).
> But when I cpoy the complete code (and file structure including kml files)
> on my Android cellphone or tablet, only the OSM map is shown, but no kml.
> Not with chrome and not with opera.
> My devices are Galaxy Tab S2 and HTC ONE M8, both Android 6.
> I want use it locale on Android devices, to beware download large kml (>10
> MB).
> Here my code:
> ### BEGIN HTML code ###
> <html>
>     <head>
>         <title>Hallo OSM</title>
>         <link rel="stylesheet" href="ol.css" type="text/css" />
>         <link rel="stylesheet" href="samples.css" type="text/css" />
>     </head>
>     <body>
>         <div id="map" class="map"></div>
>         <script src="ol.js"></script>
>         <script>
>       var vector = new ol.layer.Vector({
>         source: new ol.source.Vector({
>           url: 'kml/hydranten6.kml',
>           format: new ol.format.KML({
>               extractStyles: true,
>               extractAttributes: false,
>               maxDepth: 30
>         var ltg = new ol.layer.Vector({
>           url: 'kml/leitungen.kml',
>               maxDepth: 30
>         var osmLayer = new ol.layer.Tile({
>             source: new ol.source.OSM()
>         var musterort = ol.proj.transform([13.94, 50.96], 'EPSG:4326',
> 'EPSG:3857');
>         var view = new ol.View({
>             center: musterort,
>             zoom: 18
>         var map = new ol.Map({
>             layers: [ltg, vector],
>             target: 'map'
>         map.setView(view);
>         </script>
>     </body>
> </html>
> ### END HTML code ###
> The HTML file, ol.css, samples.css, ol.js and both kml files are stored in
> the same structure on Android as on PC and webserver.
> Any help would be appreciated.
> Thanks in advance!
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20160903/9881eae9/attachment.html>
