Accepted: [OSGeo BC] OSGeo BC Chapter - Victoria location quarterly
meeting
Dinneen, Tony
Tony.Dinneen at JacquesWhitford.com
Mon Feb 11 14:28:38 EST 2008
Hi all
I’m going to miss the meeting on the 22nd, this time I’ll be in the UK, can I send somebody else in my place?
Tony
Tony Dinneen
Group Leader - Geomatics
Jacques Whitford - Axys
11 - 2042 Mills Road West
Sidney, BC
V8L 5X4
Direct (250) 655 2281
Office (250) 656 7966
1 866 475 2997
Fax (250) 656 4789
This e-mail message, including attachments, is confidential and may be privileged. Unauthorized disclosure or distribution is prohibited.
Disclosure or distribution to anyone other than the intended recipient does not constitute waiver of privilege. If you have received this e- mail in error, please notify the sender (address above) and delete it and any attachments from your computer system and any other electronic or printed record.
Ce message électronique, incluant les pièces jointes, est confidentiel et peut être sujet à un privilège. Sa divulgation ou sa transmission non autorisée est interdite. La divulgation ou la transmission de ce message à quiconque n'en est pas le destinataire ne constitue pas une renonciation du privilege. Si vous avez reçu ce message électronique par erreur, veuillez aviser l'envoyeur (à l'adresse ci-haut) et effacer le message et ses pieces jointes de votre ordinateur ainsi que toute autre version électronique ou papier.
URL: http://lists.osgeo.org/pipermail/osgeo-bc/attachments/20080211/1a997041/attachment.html
Name: not available
Type: text/calendar
Desc: not available
Url : http://lists.osgeo.org/pipermail/osgeo-bc/attachments/20080211/1a997041/attachment.bin
More information about the OSGeo-BC
