[OSGeo BC] Workshop materials "Open Source Tools for Spatial Analysis and Geoprocessing" (WAURISA Conference 2010)
karsten vennemann karsten at terragis.net
Mon May 3 02:31:42 EDT 2010
Hi All,
I thought send this around in case anyone is interested in the materials of the OS workshop "Open Source Tools for Spatial Analysis and Geoprocessing on the desktop" at WAURISA 2010 two weeks ago (covering GDAL&OGR, gvSIG and PostGIS)...
Documents for the workshop
Workshop slides  <http://www.terragis.net/docs/workshop/OpenSpourceToolsSpatialAnalysisGeoprocessing.pdf> http://www.terragis.net/docs/workshop/OpenSpourceToolsSpatialAnalysisGeoprocessing.pdf
Cheat sheet with commands  <http://www.terragis.net/docs/workshop/waurisa_workshop_commands.txt> http://www.terragis.net/docs/workshop/waurisa_workshop_commands.txt
County data layer for the exercise in part 3 of the workshop: Land cover Analysis in gvSIG/Sextante   <http://www.terragis.net/docs/workshop/counties.zip> http://www.terragis.net/docs/workshop/counties.zip
Below my Name at the end of this message there is also a list of links to download the raw MODIS Land cover images - in case you like to become serious in trying the Land Cover Analysis exercise I showed in part three of the workshop.
If you like to try this all on your windows machine instead of running the live DVD you can download and install the windows versions:
gvSIG Oxford Archeology Digital version (2010 Beta 2) http://oadigital.net/software/gvsigoade/gvsigoade2010beta
download at ftp://88.208.250.116/gvsig-oade-2010-1.0.0.b2-windows-installer.exe
GDAL and OGR (and much more) you can install for example using http://download.osgeo.org/osgeo4w/osgeo4w-setup.exe (select all packages you like or only OGR and GDAL). More information on http://trac.osgeo.org/osgeo4w/
PostgreSQL 8.4.X http://www.enterprisedb.com/products/pgdownload.do#windows (install first)
and PostGIS 1.5.1 http://postgis.refractions.net/download/windows/pg84/postgis-pg84-setup-1.5.1-1.exe
Enjoy and let me know if you have any questions for are running into problems.
Cheers
Karsten
Karsten Vennemann
Principal
Terra GIS LTD,  Seattle, WA   <http://www.terragis.net/> www.terragis.net, Phone 206 905 1711
_________________________________________________________________________________________
MODIS download info
Download 2007 data
MCD12Q1.A2007001.h09v05.005.2009349191722.hdf
MCD12Q1.A2007001.h09v05.005.2009349191722.hdf.xml
MCD12Q1.A2007001.h10v04.005.2009349191735.hdf
MCD12Q1.A2007001.h10v04.005.2009349191735.hdf.xml
MCD12Q1.A2007001.h10v05.005.2009349191736.hdf
MCD12Q1.A2007001.h10v05.005.2009349191736.hdf.xml
MCD12Q1.A2007001.h11v04.005.2009349191758.hdf
MCD12Q1.A2007001.h11v04.005.2009349191758.hdf.xml
MCD12Q1.A2007001.h11v05.005.2009349191801.hdf
MCD12Q1.A2007001.h11v05.005.2009349191801.hdf.xml
MCD12Q1.A2007001.h12v04.005.2009349191802.hdf
MCD12Q1.A2007001.h12v04.005.2009349191802.hdf.xml
from
 <ftp://e4ftl01u.ecs.nasa.gov/MOTA/MCD12Q1.005/2007.01.01/> ftp://e4ftl01u.ecs.nasa.gov/MOTA/MCD12Q1.005/2007.01.01/
Download 2008 data
MCD12Q1.A2008001.h09v05.005.2009338155308.hdf
MCD12Q1.A2008001.h09v05.005.2009338155308.hdf.xml
MCD12Q1.A2008001.h10v04.005.2009338155502.hdf
MCD12Q1.A2008001.h10v04.005.2009338155502.hdf.xml
MCD12Q1.A2008001.h10v05.005.2009338155502.hdf
MCD12Q1.A2008001.h10v05.005.2009338155502.hdf.xml
MCD12Q1.A2008001.h11v04.005.2009338155644.hdf
MCD12Q1.A2008001.h11v04.005.2009338155644.hdf.xml
MCD12Q1.A2008001.h11v05.005.2009338155641.hdf
MCD12Q1.A2008001.h11v05.005.2009338155641.hdf.xml
MCD12Q1.A2008001.h12v04.005.2009338160213.hdf
MCD12Q1.A2008001.h12v04.005.2009338160213.hdf.xml
from
 <ftp://e4ftl01u.ecs.nasa.gov/MOTA/MCD12Q1.005/2008.01.01/> ftp://e4ftl01u.ecs.nasa.gov/MOTA/MCD12Q1.005/2008.01.01/
URL: http://lists.osgeo.org/pipermail/osgeo-bc/attachments/20100502/40485f84/attachment.html
More information about the OSGeo-BC mailing list
