[Osgeo4w-commits] r1138 - trunk/apt
svn_osgeo4w at osgeo.org
Thu Feb 11 03:12:20 EST 2010
Author: maphew
Date: 2010-02-11 03:12:18 -0500 (Thu, 11 Feb 2010)
New Revision: 1138
Added:
trunk/apt/winspecialfolders.py
Removed:
trunk/apt/specialfolders.py
trunk/apt/apt.py
* partially addresses ticket#52, now we can reliably get the start menu and desktop locations. Next step is to record the links in installed manifest.
Modified: trunk/apt/apt.py
--- trunk/apt/apt.py 2010-02-11 07:12:29 UTC (rev 1137)
+++ trunk/apt/apt.py 2010-02-11 08:12:18 UTC (rev 1138)
@@ -24,6 +24,7 @@
import gzip, tarfile
import hashlib
import subprocess
+import winspecialfolders as specialfolders
OSGEO4W_ROOT = ''
if 'OSGEO4W_ROOT' in os.environ.keys ():
@@ -34,10 +35,9 @@
sys.stderr.write ('error: Please set OSGEO4W_ROOT\n')
sys.exit (2)
-#FIXME: should this really be hardcoded?
-#FIXME: this only works for English, (e.g. called Startmenu with umlaut in a german windows)
-# related: http://trac.osgeo.org/osgeo4w/ticket/21, http://code.google.com/p/maphew/issues/detail?id=13
-OSGEO4W_STARTMENU = os.environ['USERPROFILE'] + '\Start Menu\Programs\OSGeo4W'
+# Thank you Luke Pinner for answering how to get path of "Start > Programs"
+# http://stackoverflow.com/questions/2216173
+OSGEO4W_STARTMENU = specialfolders.get(specialfolders.ALLUSERSPROGRAMS)
os.putenv('OSGEO4W_STARTMENU', OSGEO4W_STARTMENU)
root = OSGEO4W_ROOT
Deleted: trunk/apt/specialfolders.py
--- trunk/apt/specialfolders.py 2010-02-11 07:12:29 UTC (rev 1137)
+++ trunk/apt/specialfolders.py 2010-02-11 08:12:18 UTC (rev 1138)
@@ -1,48 +0,0 @@
-''' Get windows special folders without pythonwin
- Example:
- import specialfolders
- start_programs = specialfolders.get(specialfolders.PROGRAMS)
-Code is public domain, do with it what you will.
-Luke Pinner - Environment.gov.au, 2010 February 10
-#Imports use _syntax to mask them from autocomplete IDE's
-import ctypes as _ctypes
-from ctypes.wintypes import HWND as _HWND, HANDLE as _HANDLE,DWORD as _DWORD,LPCWSTR as _LPCWSTR,MAX_PATH as _MAX_PATH, create_unicode_buffer as _cub
-_SHGetFolderPath = _ctypes.windll.shell32.SHGetFolderPathW
-#public special folder constants
-DESKTOP= 0
-PROGRAMS= 2
-MYDOCUMENTS= 5
-FAVORITES= 6
-STARTUP= 7
-RECENT= 8
-SENDTO= 9
-STARTMENU= 11
-MYMUSIC= 13
-MYVIDEOS= 14
-NETHOOD= 19
-FONTS= 20
-TEMPLATES= 21
-ALLUSERSSTARTMENU= 22
-ALLUSERSPROGRAMS= 23
-ALLUSERSSTARTUP= 24
-ALLUSERSDESKTOP= 25
-APPLICATIONDATA= 26
-PRINTHOOD= 27
-LOCALSETTINGSAPPLICATIONDATA= 28
-ALLUSERSFAVORITES= 31
-LOCALSETTINGSTEMPORARYINTERNETFILES=32
-COOKIES= 33
-LOCALSETTINGSHISTORY= 34
-ALLUSERSAPPLICATIONDATA= 35
-def get(intFolder):
- _SHGetFolderPath.argtypes = [_HWND, _ctypes.c_int, _HANDLE, _DWORD, _LPCWSTR]
- auPathBuffer = _cub(_MAX_PATH)
- exit_code=_SHGetFolderPath(0, intFolder, 0, 0, auPathBuffer)
- return auPathBuffer.value
Copied: trunk/apt/winspecialfolders.py (from rev 1137, trunk/apt/specialfolders.py)
--- trunk/apt/winspecialfolders.py (rev 0)
+++ trunk/apt/winspecialfolders.py 2010-02-11 08:12:18 UTC (rev 1138)
@@ -0,0 +1,48 @@
+''' Get windows special folders without pythonwin
+ Example:
+ import specialfolders
+ start_programs = specialfolders.get(specialfolders.PROGRAMS)
+Code is public domain, do with it what you will.
+Luke Pinner - Environment.gov.au, 2010 February 10
+#Imports use _syntax to mask them from autocomplete IDE's
+import ctypes as _ctypes
+from ctypes.wintypes import HWND as _HWND, HANDLE as _HANDLE,DWORD as _DWORD,LPCWSTR as _LPCWSTR,MAX_PATH as _MAX_PATH, create_unicode_buffer as _cub
+_SHGetFolderPath = _ctypes.windll.shell32.SHGetFolderPathW
+#public special folder constants
+DESKTOP= 0
+PROGRAMS= 2
+MYDOCUMENTS= 5
+FAVORITES= 6
+STARTUP= 7
+RECENT= 8
+SENDTO= 9
+STARTMENU= 11
+MYMUSIC= 13
+MYVIDEOS= 14
+NETHOOD= 19
+FONTS= 20
+TEMPLATES= 21
+ALLUSERSSTARTMENU= 22
+ALLUSERSPROGRAMS= 23
+ALLUSERSSTARTUP= 24
+ALLUSERSDESKTOP= 25
+APPLICATIONDATA= 26
+PRINTHOOD= 27
+LOCALSETTINGSAPPLICATIONDATA= 28
+ALLUSERSFAVORITES= 31
+LOCALSETTINGSTEMPORARYINTERNETFILES=32
+COOKIES= 33
+LOCALSETTINGSHISTORY= 34
+ALLUSERSAPPLICATIONDATA= 35
+def get(intFolder):
+ _SHGetFolderPath.argtypes = [_HWND, _ctypes.c_int, _HANDLE, _DWORD, _LPCWSTR]
+ auPathBuffer = _cub(_MAX_PATH)
+ exit_code=_SHGetFolderPath(0, intFolder, 0, 0, auPathBuffer)
+ return auPathBuffer.value
More information about the osgeo4w-commits
