[Osgeo4w-commits] r1189 - trunk/apt
svn_osgeo4w at osgeo.org svn_osgeo4w at osgeo.org
Fri Apr 27 14:39:52 EDT 2012
Author: maphew
Date: 2012-04-27 11:39:51 -0700 (Fri, 27 Apr 2012)
New Revision: 1189
   trunk/apt/Notes.txt
   trunk/apt/apt.py
apt: in response to #289, refactor split_ball() to explicate the regex pattern and improve doctstring accordingly
Modified: trunk/apt/Notes.txt
--- trunk/apt/Notes.txt	2012-04-05 06:11:57 UTC (rev 1188)
+++ trunk/apt/Notes.txt	2012-04-27 18:39:51 UTC (rev 1189)
@@ -1,6 +1,10 @@
 .. @+leo-ver=5-thin
 .. @+node:maphew.20110621002235.1209: * @file Notes.txt
 .. @@language rst
+.. @+others
+.. @+node:mhw.20120404162546.1468: ** Next commit
+.. @-others
 --- To Do ---
 ... or at least think about
Modified: trunk/apt/apt.py
--- trunk/apt/apt.py	2012-04-05 06:11:57 UTC (rev 1188)
+++ trunk/apt/apt.py	2012-04-27 18:39:51 UTC (rev 1189)
@@ -1,6 +1,6 @@
 #!/usr/bin/env python
 #@+leo-ver=5-thin
-#@+node:maphew.20100310210915.1371: * @file o4w\apt\apt.py
+#@+node:maphew.20110428135158.2655: * @file apt.py
 #@@first
 #@+<<docstring>>
 #@+node:maphew.20100307230644.3846: ** <<docstring>>
@@ -793,15 +793,47 @@
     return t[0] + '-' + version_to_string (t[1])
 #@+node:maphew.20100223163802.3761: *3* split_ball
-def split_ball (p):
-    # ''' Parse version number from package archive name '''
-    # mc-4.6.0a-20030721-1.tar.bz2
-    #m = re.match ('^([^.]*)-([0-9][^-/]*-[0-9][0-9]*)(.tar.bz2)?$', p)
-    m = re.match ('^([^.]*)-([0-9].*-[0-9][0-9]*)(.tar.bz2)?$', p)
+def split_ball (filename):
+#    ''' Parse package archive name into a) package name and b) version numbers tuple (to feed into version_to_string)
+#    mc-4.6.0a-20030721-12.tar.bz2
+#      mc              --> package name
+#      4.6.0a-20030721 --> upstream application version
+#      12              --> package version
+#    python-numpy-2.7-1.5.1-1.tar.bz2
+#      python-numpy  --> package name
+#      2.7-1.5.1     --> upstream application version
+#      1             --> package version
+#      returns:
+#           ('mc', (4, 6, 0a, 20030721, 12))
+#           ('python-numpy', (2, 7, 1, 5, 1, 1))
+    ##m = re.match ('^([^.]*)-([0-9][^-/]*-[0-9][0-9]*)(.tar.bz2)?$', filename)    # original regex from cyg-apt
+    ##m = re.match ('^([^.]*)-([0-9].*-[0-9][0-9]*)(.tar.bz2)?$', filename)        # accept dash in app ver num
+    # this regex pattern should be functionally identical to the line immediately above
+    regex = re.compile('''
+       ^       	    # beginning of line
+       ([^.]*) 	    # package name: any char except period, and any amount of them, "python-numpy"
+       -                # name/version delimiter
+           [0-9].*    # application version: any number followed by any char, any amount of them, "4.6.0a-20030721"
+           -[0-9]*    # package version: dash followed by number, "-12"
+       (\.tar\.bz2)?$
+       ''', re.VERBOSE)
+    m = re.match(regex, filename)
     if not m:
-        print '\n\n*** Error parsing version numer from "%s"\n\n' % (p)
-    return (m.group (1), string_to_version (m.group (2)))
+        print '\n\n*** Error parsing version number from "%s"\n%s\n' % (filename, m)
+    return (m.group(1), string_to_version(m.group (2)))
 #@+node:maphew.20100223163802.3762: *3* string_to_version
 def string_to_version (s):
     # bash-2.05b-9
More information about the osgeo4w-commits mailing list
