[osgeo4w-dev] Setup problems on Win64 and Windows Server 2003
Tamas Szekeres szekerest at gmail.com
Fri Mar 21 16:19:30 EDT 2008
I'd add to my previous statements that the big setup cannot be
renamed. If I rename the file eg. to osgeo4w-setup1.exe then the
crashing issue is stepping up. The compressed version can be renamed
without problems though.
Best regards,
Tamas
2008/3/21, Tamas Szekeres <szekerest at gmail.com>:
> Frank,
>  I've just tried the current installer (compressed) and the yesterday's
>  version and both were working pretty well on my Win2003 x64 R2. I
>  wonder why you've found such problems with the current version.
>  Best regards,
>  Tamas
>  2008/3/21, Frank Warmerdam <warmerdam at pobox.com>:
> > Folks,
>  >  Tamas has experienced problems with osgeo4w-setup.exe crashing on startup
>  >  on Win64.  I ran into apparently the same problem on Windows 2003 Server.
>  >  All documented at:
>  >    http://trac.osgeo.org/osgeo/ticket/234
>  >  I have done some debugging of the problem on the win2003 server system
>  >  and managed to hack my way around it by disabling a bunch of fancy win32
>  >  stuff.  I have committed this, and uploaded a new setup that will skip
>  >  some stuff when run in safe mode.  To enable safe mode pass --safe on the
>  >  commandline.  This can be edited into the desktop icon for instance.
>  >  I would appreciate folks with Win64 or win2003 server systems trying without
>  >  and with this switch and noting experiences in the ticket.  If anyone has
>  >  direct physical access to such a machine and wants to try debugging the problem
>  >  properly that would also be appreciated.
>  >  PS. the latest osgeo4w-setup.exe is also compressed with upx and is only 300K!
>  >  PPS. I would like to actually package the setup program so folks can easily
>  >  and reliably launch it from the osgeo4w shell commandline (and start menu)
>  >  instead of having to keep around the downloaded .exe.
>  >  Best regards,
>  >  I set the clouds in motion - turn up   | Frank Warmerdam, warmerdam at pobox.com
>  >  light and sound - activate the windows | http://pobox.com/~warmerdam
>  >  and watch the world go round - Rush    | President OSGeo, http://osgeo.org
>  >  _______________________________________________
>  >  osgeo4w-dev mailing list
>  >  osgeo4w-dev at lists.osgeo.org
>  >  http://lists.osgeo.org/mailman/listinfo/osgeo4w-dev
More information about the osgeo4w-dev mailing list
