[osgeo4w-dev] gdal-python packages & gdal_merge
Wed Oct 8 10:46:19 EDT 2008
fabienne picot wrote:
> Hi
> I would like to use the command gdal_merge with OSGeo4W, but it is not include in it.
>  Could you tell me how to install gdal-python packages and this command?
Fabienne,
You should go through the advanced install, and find the gdal-python package
within it as described in this email:
http://lists.osgeo.org/pipermail/osgeo4w-dev/2008-October/000220.html
Note that there is a gdal_merge.bat cover script in OSGeo4W so you would
actually run gdal_merge at the commandline without any extension.
eg.
gdal_merge -o mosaic.tif  image1.tif image2.tif image3.tif
Best regards,
More information about the osgeo4w-dev mailing list
