[osgeo4w-dev] gdal-python packages & gdal_merge
fabienne picot cfab13 at hotmail.fr
Fri Oct 10 09:19:40 EDT 2008
That's ok: I have uninstall the gdal-sde and gdal-ecw plugin packages
Now when I type "gdalinfo",I get this:
Usage: gdalinfo [--help-general] [-mm] [-stats] [-hist] [-nogcp] [-nomd]
[-noct] [-checksum] [-mdd domain]* datasetname
So what do I do now?
> Date: Fri, 10 Oct 2008 08:16:21 -0400
> From: warmerdam at pobox.com
> To: cfab13 at hotmail.fr
> CC: osgeo4w-dev at lists.osgeo.org
> Subject: Re: [osgeo4w-dev] gdal-python packages & gdal_merge
> fabienne picot wrote:
> > Is the command:
> > C:\OSGeo4W>gdalinfo  ??
> > Because this one doesn't work. But I just begin with the command line,
> > and I don't know really the correct synthaxe.
> Fabienne,
> I was thinking of just typing "gdalinfo" at the commandline.   You
> should get a usage message something like:
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam, warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | Geospatial Programmer for Rent
_________________________________________________________________
Téléphonez gratuitement à tous vos proches avec Windows Live Messenger  !  Téléchargez-le maintenant !
http://www.windowslive.fr/messenger/1.asp
URL: http://lists.osgeo.org/pipermail/osgeo4w-dev/attachments/20081010/444d6e69/attachment.html
More information about the osgeo4w-dev mailing list
