[osgeo4w-dev] EPPL7 problem still exists
Yewondwossen Assefa yassefa at dmsolutions.ca
Tue Sep 16 09:29:25 EDT 2008
Derek,
  Does gdalinfo.exe reads your ecw properly?
Derek Bain wrote:
> Hi
> I installed the gdal-ecw plugin package from the link supplied and
> followed the instructions, but my problem still exists. I registered
> NCSEcw.dll ... the other dll's did not need to be registered.
> Do you have any other thoughts as to what might be wrong??
> many thanks
> Derek
> C:\OSGeo4W\bin>mapserv -v
> MapServer version 5.2.0 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
> OUTPUT=SWF
>  OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=ICONV
> SUPPORTS
> =FRIBIDI SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER
> SUPPORTS=WF
> S_CLIENT SUPPORTS=WCS_SERVER SUPPORTS=SOS_SERVER SUPPORTS=FASTCGI
> SUPPORTS=THREA
> DS SUPPORTS=GEOS INPUT=JPEG INPUT=POSTGIS INPUT=OGR INPUT=GDAL
> INPUT=SHAPEFILE
> C:\OSGeo4W\bin>shp2img -m d:\test_maps\ecw.map -o d:\test_maps\test.png
> -map_debug 5
> msDrawRasterLayerLow(Mosaic_0): entering.
> drawEPP(): Image handling error. EPPL7 support is not available.
> msDrawRaster(): Image handling error. Unrecognized or unsupported image
> format
> msDrawMap(): Image handling error. Failed to draw layer named 'Mosaic_0'.
> 'Mosaic_0'. <br>
> format <br>
> drawEPP(): Image handling error. EPPL7 support is not available. <br>
> msFreeMap(): freeing map at 0127B2E8.
> osgeo4w-dev mailing list
> osgeo4w-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/osgeo4w-dev
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax:   (613) 565-0925
More information about the osgeo4w-dev mailing list
