[osgeo4w-dev] [osgeo4w] #48: qgis.bat uses PATH assumptions -- won't start up
OSGeo4W trac_osgeo4w at osgeo.org
Wed Feb 4 16:46:55 EST 2009
 Reporter:  mwtoews  |       Owner:  osgeo4w-dev at lists.osgeo.org
     Type:  defect   |      Status:  new
 Priority:  major    |   Milestone:
Component:  Package  |     Version:
 Keywords:           |
 I have OSGeo4W installed in a non-default location C:\gnu\OSGeo4W
 As of the latest QGIS update, I cannot open QGIS normally (e.g., from the
 Start Menu) since qgis.bat uses assumptions with the installation
 directory:
 SET OSGEO4W_ROOT=C:\OSGeo4W
 this path is not correct for my setup. This is an easy fix for me, but not
 an "out of box" solution for others.
 (Last one for today Frank :)
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/48>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer for the OSGeo stack.
More information about the osgeo4w-dev mailing list
