[osgeo4w-dev] compile grass module in OSgeoW
sirius spelta sirius.spelta at gmail.com
Sun Feb 15 11:43:55 EST 2009
hy,
Is not clear for me if I've to launch make from osge4w shell or from msys.
Anyway, if I've to run make from c:\osge4w, where can I put grass source and
grass_addons directory.
Exuse if that is a trivia matter, but I'm not a professional programmer.
Thanks
ss
2009/2/15 Jürgen E. Fischer <jef at norbit.de>
> Hi Sirius,
> On Sun, 15. Feb 2009 at 17:13:03 +0100, sirius spelta wrote:
> >  The tutorial in
> http://grass.osgeo.org/grass63/binary/mswindows/native/#Build
> > GRASS From Source is clear for 6.3.0 but the envirnment is different and
> I'v
> > some problems in OSgeo4w for 6.4.0.
> Hm, what's the problem?   Except that the dependencies like GDAL are
> taken from OSGeo4W the build process isn't significantly different.
> Jürgen
> Jürgen E. Fischer         norBIT GmbH               Tel. +49-4931-918175-20
> Dipl.-Inf. (FH)           Rheinstraße 13            Fax. +49-4931-918175-50
> Software Engineer         D-26506 Norden
> http://www.norbit.de
> norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
> Rheinstrasse 13, 26506 Norden
> GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
> osgeo4w-dev mailing list
> osgeo4w-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/osgeo4w-dev
URL: http://lists.osgeo.org/pipermail/osgeo4w-dev/attachments/20090215/c10a777f/attachment.html
More information about the osgeo4w-dev mailing list
