[osgeo4w-dev] Re: [osgeo4w] #37: grass: wxpython gui issues
OSGeo4W trac_osgeo4w at osgeo.org
Mon Feb 23 19:38:04 EST 2009
  Reporter:  jachym   |       Owner:  osgeo4w-dev at lists.osgeo.org
      Type:  defect   |      Status:  new
  Priority:  major    |   Milestone:
 Component:  Package  |     Version:
Resolution:           |    Keywords:  GRASS
Comment (by hamish):
 > Replying to [comment:24 hamish]:
 > > if you click "browse EPSG codes", you get an error that the
 > > file can't be found. If you browse for the EPSG file, the
 > > path becomes `C:/OSGeo4W/share/proj/epsg` and then it all
 > > works: ie the nice code table browsing, searching, & grabbing.
 Replying to [comment:25 marisn]:
 > Path in Tcl/Tk is taken from env variable: GRASS_PROJSHARE that
 > is set during compilation(?). Make it correct on Windows and
 > there will be no error messages.
 usually set in ./configure with --with-proj-share=/usr/share/proj
 or so. I think that only sets the path for the EPSG codes browser/
 search GUI; g.proj uses the PROJ4-linked version regardless of what you
 set that path to. Not sure if things have changed though.
 Hamish
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/37#comment:26>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer for the OSGeo stack.
More information about the osgeo4w-dev mailing list
