[osgeo4w-dev] Re: [osgeo4w] #61: Dependencies not automatically selected
OSGeo4W trac_osgeo4w at osgeo.org
Wed Feb 25 20:18:22 EST 2009
  Reporter:  cnielsen   |       Owner:  osgeo4w-dev at lists.osgeo.org
      Type:  defect     |      Status:  new
  Priority:  major      |   Milestone:
 Component:  Installer  |     Version:
Resolution:             |    Keywords:  grass
Comment (by hamish):
 In  http://download.osgeo.org/osgeo4w/setup.ini  both gdal and gdal16 both
 "requires:" curl, expat, etc. so it doesn't seem to be a packaging
 mistake, more of a cygwin installer problem...?
 perhaps if the downloads get interrupted part way through the install
 process it continues anyway with what it's got??
 ISTR we've seen a very similar problem with the GRASS cygwin installer in
 the past.
 Hamish
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/61#comment:5>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer for the OSGeo stack.
More information about the osgeo4w-dev mailing list
