[osgeo4w-dev] About Vista 64 bit
andrea antonello andrea.antonello at gmail.com
Fri Jan 23 13:03:01 EST 2009
Hi Andrea,
I just installed it on Vista 32 bit and it doesn't run.
I was able to run it from within a cygwin shell only after modifying
the paths, inside the start scripts. It freezed when I tried to open a
mapset.
No idea what goes on.
Andrea
On Fri, Jan 23, 2009 at 6:16 PM, iomeneandrei <aborruso at tin.it> wrote:
> Dear all,
> I have installed Grass using osgeo4w-setup.exe, as explained here:
> http://gfoss.blogspot.com/2009/01/wingrass-640rc2-now-available.html
> I'm not able to run GRASS, it crushes immediately. I'm using it in 64bit
> Vista. Is there some compatibility issue?
> Thank you,
> Andrea
> Andrea Borruso
> email: aborruso at tin.it
> blog: http://blog.spaziogis.it
> View this message in context: http://n2.nabble.com/About-Vista-64-bit-tp2204487p2204487.html
> Sent from the osgeo4w-dev -- OSGeo Win32 Installer List mailing list archive at Nabble.com.
> osgeo4w-dev mailing list
> osgeo4w-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/osgeo4w-dev
More information about the osgeo4w-dev mailing list
