[osgeo4w-dev] workflow for uploading and testing a new package?
Matt Wilkie maphew at gmail.com
Wed Jan 28 04:28:27 EST 2009
*sigh* nevermind. As I was settling into sleep I realised I hadn't
uploaded the setup.hint file. After I did so the regen script worked
as expected.
Now I learn that osgeo4w-setup.exe doesn't like the tar.bz2 archives
created by 7zip. I'll leave that problem for tomorrow I think.
 My apologies for the false alarm. :)
-matt
On Wed, Jan 28, 2009 at 12:54 AM, Matt Wilkie <maphew at gmail.com> wrote:
> Hi Frank,
> I tried to use the workflow described but the setup_test.ini does not
> contain the new package. Here is what I did:
> 1. Use WinSCP, login as maphew, and upload apt-0.0-1.tar.bz2 to
> /osgeo/download/osgeo4w/release/apt
> 2. Point web browser to
> http://upload.osgeo.org/cgi-bin/osgeo4w-regen.sh. After a few minutes
> I get a message saying the setup_test.ini is built.
> 3. Point browser at /download_data/download/osgeo4w/setup_test.ini to
> have a look, Apt is not there.
> I repeated a couple of times to make sure I didn't over look something
> and got the same results.
> (((a usability note: I would leave out the hyperlink from the "File
> generated, after testing promote to live". It's the only link on the
> page and would be easy to activate by accident. Perhaps instead link
> to the packaging instructions page which links to the promote script.
> Or something.
> Speaking of promote script, the link to it on the packinging
> instructions wiki page was broken, I fixed the link but didn't test
> it.)))
> The ./apt directory is owned by maphew while all the others are owned
> by apache. Perhaps that is messing things up?
> best regards,
> -matt
> On Wed, Jan 21, 2009 at 10:58 PM, Frank Warmerdam <warmerdam at pobox.com> wrote:
>> Matt Wilkie wrote:
>>> Hello,   what is the workflow for uploading and testing a new package?
>>> I've added a postinstall action to gdal-python for creating .bat for
>>> .py's, c.f. http://trac.osgeo.org/osgeo4w/ticket/17, placed it in a
>>> local .bz2 archive with version number incremented
>>> (gdal-python-1.5.2-2.tar.bz2) but am not sure what to do with it now.
>>> I haven't found a staging area on the server or information on how to
>>> test uploaded packages before they go live to everybody.
>> Matt,
>> In the past you would login to upload.osgeo.org and run the regen.sh
>> script to recreate the setup.ini file with the new packages.
>> However, this gave no opportunity to do a real test of new packages
>> before they were live for others.  So tonight I have made a few changes.
>> Primarily, I modified things so we have a setup_test.ini file on the
>> server which we can use for testing (by passing -t to setup.exe).  This
>> file is produced by the regen.sh, and now an extra step is required to
>> promote this file to the official location (setup.ini).
>> Furthermore, I have added web accessable cgi's to do the regen and
>> promote steps.
>>  * http://upload.osgeo.org/cgi-bin/osgeo4w-regen.sh : Generate test setup
>>  * Test by passing -t to setup program.
>>  * http://upload.osgeo.org/cgi-bin/osgeo4w-regen.sh : Promote test to live
>> I have updated the PackagingInstructions to refer to this:
>>  http://trac.osgeo.org/osgeo4w/wiki/PackagingInstructions
>> To streamline this I have also changed the whole /osgeo4w/download/osgeo4w
>> tree to be owned by apache.apache, and for all directories to have "all"
>> write permissions.
>> Hopefully this will make it easier for us as packagers to responsibly
>> test new packages before they are deployed for end users.
>> Best regards,
>> I set the clouds in motion - turn up   | Frank Warmerdam,
>> light and sound - activate the windows | http://pobox.com/~warmerdam
>> and watch the world go round - Rush    | Geospatial Programmer for Rent
> -matt
-matt
More information about the osgeo4w-dev mailing list
