[osgeo4w-dev] Fwd: winGRASS 6.4.0RC3 available in OSGeo4W test mode (Markus Neteler)
Isaac Ullah isaac.ullah at asu.edu
Thu Jan 29 12:21:30 EST 2009
---------- Forwarded message ----------
Date: Jan 28, 2009 9:16 PM
Subject: Re: winGRASS 6.4.0RC3 available in OSGeo4W test mode (Markus
Neteler)
To: grass-windows at lists.osgeo.org
I get the following errors when starting GRASS after OsGeo4W install process
(both 6.4.RC3, and  standard 6.4):
Start GRASS from icon or cmd. Choose location/mapset, hit run. Get firs
error:
Error setting region (Problem with g.region?): child killed:segmentation
violation
Press OK, then:
g.proj or projection error: child killed: segmentation violation
Press OK, then:
can't read "monitor_zooms(1,1,n)": no such variable while executing
"lappend region $monitor_xooms($mon,1,4attr)" (procedure
"MapCanvas::currentzoom"line 15) invoked from within
"MapCanvas::currentzoom $mon" (procedure "MapCanvas::currentzoom" line 23)
invoked from within
"MapCanvas::coordconv $mon" (procedure "MapCanvas::create" line 68) invoked
from within
"MapCanvas::create" (procedure "Gm::startmon" line 11) invoked from within
"Gm::startmon" (procedure "Gm::create" line 79) invoked from within
"Gm::create" (procedure "main" line 30) invoked from within
"main $arfc $argv" (file
"C:\OSGeo4W/apps/grass/grass-6.4.0RC3\etc\gm\gm.tcl" line 566)
Press OK, then GRASS quits.
I still have GRASS 6.3 windows native version installed, but don't think
that that should be causing this issue since OsGeo4W seems to keep it's
packages seperate after install. Intersting to see the strange juxtiposition
of PC and *nix slashes in the last line of the third error. Is that parsed
correctly?
For install options, I only chose to install GRASS, and let the OsGEO4W pick
dependencies... Seems to have downloaded and installed everything, but is it
possible there is some problem with the OsGeo4W intallation of Proj when
doen this way?
Cheers,
Isaac
On 1/28/09, grass-windows-request at lists.osgeo.org <
grass-windows-request at lists.osgeo.org> wrote:
> Send grass-windows mailing list submissions to
> To subscribe or unsubscribe via the World Wide Web, visit
>         http://lists.osgeo.org/mailman/listinfo/grass-windows
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
>         grass-windows-owner at lists.osgeo.org
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of grass-windows digest..."
> Today's Topics:
>    1. winGRASS 6.4.0RC3 available in OSGeo4W test mode (Markus Neteler)
> Message: 1
> Date: Wed, 28 Jan 2009 17:56:12 +0100
> From: Markus Neteler <neteler at osgeo.org>
> Subject: [GRASS-windows] winGRASS 6.4.0RC3 available in OSGeo4W test
>         mode
> Message-ID:
>         <86782b610901280856h348bc8dr4dd7c7cc6fd3d44c at mail.gmail.com>
> Content-Type: text/plain; charset=ISO-8859-1
> The winGRASS 6.4.0RC3 has been packaged, for now in test mode (new
> digitizer and wxnviz yet not included):
> To install (note the -t) run:
> C:\osgeo4w-setup.exe -t
> Al before, in the "Advanced installer", you find GRASS. It should
> find its dependencies automatically now.
> The previously missing g.mlist has been included now.
> Thanks to Jef Fischer for packaging it,
> Markus
> End of grass-windows Digest, Vol 29, Issue 17
Isaac I Ullah, M.A.
Archaeology PhD Student,
ASU School of Evolution and Social Change
Research Assistant,
Mediterranean Landscape Dynamics Project
ullah at archaeologist.com
http://www.public.asu.edu/~iullah
Isaac I Ullah, M.A.
Research Assistant,
URL: http://lists.osgeo.org/pipermail/osgeo4w-dev/attachments/20090129/1b9a6ac9/attachment.html
More information about the osgeo4w-dev mailing list
