[osgeo4w-dev] [osgeo4w] #67: QGIS *.bat is not changed and QSQLITE lost if installed in different dir
OSGeo4W trac_osgeo4w at osgeo.org
Wed Mar 18 17:13:45 EDT 2009
Reporter:  gislab  |       Owner:  osgeo4w-dev at lists.osgeo.org
    Type:  defect  |      Status:  new
Priority:  major   |   Component:  Installer
 Version:  1.0     |    Keywords:
 Under Windows XP, if QGIS and other stuff installed in the folder
 different from C:\OSGeo4W, lets say to C:\Gis\OSGeo4W, 2 problems emerge:
 1. To be able to run QGIS, qgis.bat should be edited to reflect change in
 the install folder
 2. QSQLITE driver doesn't show up in the list of sources of QGIS and
 subsequently SQLite drivers cannot be used.
 If QGIS is installed with Express option to C:\OSGeo4W folder, everything
 works ok by default.
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/67>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer for the OSGeo stack.
More information about the osgeo4w-dev mailing list
