[osgeo4w-dev] Re: [osgeo4w] #81: qgis-grass plugin does not work
OSGeo4W trac_osgeo4w at osgeo.org
Thu May 7 07:37:27 EDT 2009
Reporter:  timmie       |        Owner:  osgeo4w-dev at lists.osgeo.org
    Type:  defect       |       Status:  new
Priority:  major        |    Component:  Package
 Version:               |   Resolution:
Keywords:  grass, qgis  |
Comment (by hamish):
 Replying to [comment:3 timmie]:
 > 1) open QGIS as installed by OSGEO4W
 > 2) open a mapset
 > 3) open the GRASS toolbox
 > 4) try to launch the v.in.ogr command.
 ( from Import -> Vector )
 again, works for me. I see the module GUI, can click on and off options,
 If I run it with bogus in= and out= names I get an error that says the
 datasource can't be found....
 does v.in.ogr work from the osgeo4w grass GUI?
 Hamish
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/81#comment:4>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer for the OSGeo stack.
More information about the osgeo4w-dev mailing list
