[osgeo4w-dev] GEOS 3.0.3-2
Wed May 13 00:25:29 EDT 2009
Folks,
In order to correct some serious problems with GDAL packages depending on
GEOS I have rebuilt and issued a GEOS 3.0.3-2 package.  It appears I built
GEOS 3.0.3-1 with VisualStudio 2008.  However, it turns out that there is at
least one GDAL cross-heap allocation problem when using GEOS that requires
(for now) that they have the same runtime C library.  So the -2 package it
built with VS 2003.
The problem with GEOS is described in:
   http://trac.osgeo.org/geos/ticket/249
For the purpose of GDAL, the particular problem is the use of free()
on the result of GEOSGeomToWKT_buf() in OGRGeometryFactory::createFromGEOS().
This email is partly a warning notice to anyone who used GEOS for their
package and possibly depended on it using the VS2008 runtime.
Best regards,
More information about the osgeo4w-dev mailing list
